If you email the latest port map you did, and explain how the piston is above ALL the port bottoms meaning the ports never fully open. I think he will get it right off the bat. (If he has any understanding of what he is selling) There may well be a needed spacer for the bottom of the jug, and a crank/con rod kit made just for that jug, but as josh is facing the same troubles w/ a supplied crank kit I dont really think that is the case. I think the port map, a http address for your thread, some of the photos you took, and detail all the trouble, and money invested. That should be enough to get a satisfactory response from him. The trouble w/ a prelim port map is you just wont know where they fall w/ out the matching piston actually mounted on your crank. Proven Products Bro! Josh at invasion also runs a shop from his house. Maybe he has a used kit, or a contact who can supply one. His posters are all over the globe as well as here, but they are much more into tuning on invasion, so I believe there would be alot more spare kits to go around from there. I'll PM him right now to see wuz up. One way or another we will get you scootin!
