Is some rice white? HEdoublehockeysticks YEAH! It would be soooo much better to se Sid's kit screamin' first. I think all the ports are below the piston from the map. If so a Major rebuild of the crank/con rod/cases, and cutting the top of the jug would correct it. The cc's would also go down thus negating the point of the kit! What happens w/ these China kits is "someone" sits down and takes picts of a good kit, and loads the picts. into a simple CAD program that can run thousands of "knock offs" a week! They flood mostly developing nations with CHEAP merchandise, and the failure rate is mostly un-reported. There are 2 "Thunder dragon" kits that I know of, and they have the same problem. I live in a S W A M~ F'N ~P, and know about it. BUTTTT... I never give up on a part unless it cracks or breaks. Zombie is not just an internet name. Everyone calls me zombie because if it is mechanical in nature, and considered DEAD... I bring it to life! "Parts are parts" Even if the name on the jar said Aby someone! Aby whom you may ask? Aby Normal I think.
