G'Day all, I managed to pick up a piece of aluminium today but I could only get 1.6mm or 3mm, so I took the 3. BUT, having been reading The Two Stroke Tuner's Handbook I came across the part about the ports. In this section he suggests that rather than trying to machine the ports it is better to notch the piston to try the adjustment. Do you reckon this might be worth a try, or should I just go ahead with the spacer idea?
