G'Day Blokes, computer is giving a little grief. I did another port map, will attach a photo, piston is now just slightly proud at the front but seems flush at the rear. Piston at B.D.C. is 41.3mm, ex. port is 21.75mm, left trans. ports 30.26, boost port 29.78, right trans. ports 30.01, these measuerements are from the top of the cylinder to the top of the ports. The transfer ports are slightly above the piston @ B.D.C. I have taken it for a ride and though not getting to top speed as quick it seems to have lost some of that bog above 1/2 throttle. This port map I put the numbers on upside down, oops.
