Last night I pulled the head off again to put in another spacer and saw the piston was a touch over the bottom of the ports so I played with some gaskets and now have the piston a shade below the port and deck height just slightly in the negative but only a bees dick. I now have the head on with only one gasket so that should be a squish of about 1.2mm, roughly. I know I should be taking measurements. No detonation last night but still with carb tune probs. with the air cleaner clogging up it seems to be with oil not dirt. After reading Gordon jenning's book I see how the fuel does blow back along the inlet tract, with my filter getting clogged with oil would that mean I need to lengthen the air filter tube or maybe reduce the oil mix, I am currently running 300ml. to 10litres of fuel, I believe that gives a ratio of about 32:1. I have bought a new filter for it today, wanted a spare before I wash it with kerosens or petrol just incase it damaged it. Looking up from here.
