Yeah Shaka. Just follow the instructions form the other post slinger high lighted. I tossed the map I made when I moved, but remember it started at 15 before, went to 18-19 around 4000, and fell back to 13 to the top. It is real easy to mark it out on the case. I used a sharpee. The tough bit was holding the throttle steady to get it right. I wound up pulling a zip tie between the throttle, and the fairing to hold it steady for me. Mark your case, and flywheel ANYWHERE for tdc , the numbers will come out the same no matter where you start from. Just be sure you have clear space to see going up to 25 or so degrees backwards.
