I have raised the jug a little and got a compromise between port height and head spacer, there is some detonationat backoff, currently running a BR9HS plug but have not yet indexed it. Scoot is running ok but still a little bog over 3/4 throttle, that reduced when I dropped the needle to the lowest setting so am thinking of using a smaller jet (more chops). The only problem with the needle in this position is less control with throttle it is more on/off at low to mid speed cruising, (thinking smaller jet, higher needle).
Has been running ok though, will check out the clutch today and put in the sliders, that should put a smile on my face.
Have been meaning to update the 82cc upgrade thread too, just have to take a pic of the current port map/position and get some details together, I have a bad habit of not documenting things as I go.
