...okay, here's what i found to work for me...
..though, i believe i may have a different carburetor, piston and rings than some other A50s in th' field...
..Malossi variator with 4.7 gr Leo Vince rollers...white "1000" malossi main torque drive spring..(helps maintain higher rpms during a slow-down, and shift's you into a better gear ratio up steep hills)...would like a "1500"...
..free-flow air filter with whatever jet keeps ur scoot running not lean...but almost a little bit lean...i thinks it's faster...
..i'd state my main jet size...but i ain't going to open that can of worms again...
..red +50 Leo Vince fly clutch springs.. for a revving good take-off...
..gotta have a drive belt in good condition...
..gotta have a GOOD set of tires with a high run speed rating...(there's a technical term for that)..my new Avons are ratd at 110 mph..
..gotta keep ur oil changed often, and on broken-in A50's, i'd recommend a good synthetic oil...(resists thermal breakdown better than dino-fluids)...
...keep you scoot's valves adjusted to .04mm on the intake and .03mm on th exhaust...
..that adjustment, and changing your oil often, are crucial to your scoot's overall performance and longevity...
peace
..just my own observations and experience...
![Grin ;D](https://www.kymcoforum.com/Smileys/default/grin.gif)
