Author Topic: WANT MY SCOOT TO WORK!!!!!!!!!!!!  (Read 2132 times)
Kimcofan
« on: February 12, 2010, 05:33:22 AM »
I really want to get my scoot running, I wont be able to work on it this weekend ONCE AGAIN. Its supposed to snow on Monday and I havent had time during the week due to school/work anyway!!!  I guess Im gonna have to wait a WHOLE WEEK once again, well Ill tell you what next weekend NOTHING IS GOING TO GET IN MY WAY!!!!!  I am about to turn into the Incredible Hulk and tear some stuff up!  JUST WANT TO RIDE AGAIN.  There is still the problem of not exactly knowing whats going on as well but cant figure it out till I have time to fiddle.  If I cant get it next weekend to the shop we go :-\
Re: WANT MY SCOOT TO WORK!!!!!!!!!!!!
« Reply #1 on: February 12, 2010, 06:08:49 AM »
Ok Bro! Start again so I can keep Track. I suck at finding links. You did a 4t bbk conversion right? You will get it running HERE. No Doubt! Ever here of the Corn Flake Girl? You bet your life! Keep Posting Bro!
Kimcofan
« Reply #2 on: February 12, 2010, 02:55:43 PM »
Did the 72 cc kit put together correctly, timed correctly, and all hookups are correctly hooked up.  I haven't put the exhaust on yet but when I sprayed ethanol in the carb it didnt start I am going to make sure valves are adjusted correctly when I get a chance to work on it.  It could also be the cdi, but scoot would start and run before big bore kit was installed so I am skeptical about the cdi.  I would think with the ethanol sprayed in the carb it would have started so im thinking there isnt a spark, so i am planning on gettting a new plug as well.  If those things dont work I was going to take it to a shop So unless you can think of anything else let me know im open to suggestions.
jprestonian
    • a scooter called wanda
« Reply #3 on: February 12, 2010, 03:34:13 PM »
I hope you're spraying ether, not ethanol in the carb.
« Reply #4 on: February 12, 2010, 06:39:10 PM »
No doubt on the ether. I would think you are on the right track with the new plug, and double checking the valves. when cranking the engine do you feel GOOD STRONG compression?
Kimcofan
« Reply #5 on: February 12, 2010, 10:24:39 PM »
havent done compression test but there is a new crank piston and head I dont see why there wouldnt be good compression
Shaka
« Reply #6 on: February 12, 2010, 11:46:29 PM »
Have you checked for spark by plugging in the spark plug and carefully touching the metal threaded part to the engine case while cranking the motor?  You should be able to easily see the spark jumping across the the electrode.  Just be sure to hold the rubber insulated part of the plug cap!  Don't be too afraid, it doesn't hurt too bad if you do get shocked! ;)
Kimcofan
« Reply #7 on: February 13, 2010, 01:05:43 AM »
I was planing on checking it I have a spark plug tester, but there isnt a cap on the plug so it wouldnt work,  I couldnt find a cap anywhere, but I havent tried putting it up against anything yet wont be able to get to it till next weekend  :-\
« Reply #8 on: February 13, 2010, 01:07:36 AM »
The compression test will show if there is a problem with the valve lash or timing.
« Reply #9 on: February 13, 2010, 01:39:19 AM »
..dude, i hope you figure out what happened...
..so, if i got this right...you did the kit..verified timing is correct...seems you installed a new stator...
..was it compatible with your cdi ??? ...did you verify that it will work with a kymco A50 cdi?
« Reply #10 on: February 13, 2010, 01:53:47 AM »
...famous last words...........
..but shaka is right...that will work...think we talked about this procedure before....
« Last Edit: February 13, 2010, 01:55:51 AM by wordslinger »
Shaka
« Reply #11 on: February 13, 2010, 03:54:01 AM »
I get shocked all the time!  Maybe, I'm just used to it! ;)
« Reply #12 on: February 13, 2010, 03:55:41 AM »
...zzzzzt!!..
....i'm an electrician by trade...so again....
 :o
