Author Topic: my zx50 issues  (Read 109517 times)
Re: my zx50 issues
« Reply #240 on: May 14, 2010, 02:13:00 AM »
It's almost all the way down and sometimes hard to see!
..i use a magnifying glass and a penlight...
thebatman
Re: my zx50 issues
« Reply #241 on: May 14, 2010, 02:14:37 AM »
ok, i try that......i am running the factory 14mm wit stock jug, head to... (2DIFFERENT SHOPS TOLD ME TODAY, NO REASON TO, WASTE OF TIME, POINTLESS... told you cant really tune oem carb to make ANY sort of change)
"THE BAT"MAN...
Says:
Re: my zx50 issues
« Reply #242 on: May 14, 2010, 02:15:51 AM »
...that's not true...
..i tuned my stock carb to run my A50 over 50mph...
...downhill...lol...
« Last Edit: May 14, 2010, 02:20:32 AM by wordslinger »
Shaka
Re: my zx50 issues
« Reply #243 on: May 14, 2010, 02:21:09 AM »
I'm sitting here with my stock carb opened up now after checking the main jet.  It appears that the pilot jet is not replaceable?!  I guess it is tune-able to a point.
thebatman
Re: my zx50 issues
« Reply #244 on: May 14, 2010, 02:25:23 AM »
ok, just looked at plugs.. are you talking about a ring shape thats IN BETWEEN ceramic portion and steel "case"/"body"?? looking straight down into plug!...       if so, then the wot plug was a tan  ish color........ the 1/4 plug was black...
"THE BAT"MAN...
Says:
sidthesloth
  • Kymco ZX50
Re: my zx50 issues
« Reply #245 on: May 14, 2010, 02:26:45 AM »
My stock carb had an 85 jet, but had already been played around with before me. I was just next in line. :-)
thebatman
Re: my zx50 issues
« Reply #246 on: May 14, 2010, 02:30:08 AM »
by pilot jet, you ARE reffering to the brass rod that runs alongside the main jet???  it is removeable, ivr done it... supposedly thats how i screwed up the other carb.. there are 4 cross drilled holes (2 & 2 )in the head of it that sinks into carb..
"THE BAT"MAN...
Says:
Shaka
Re: my zx50 issues
« Reply #247 on: May 14, 2010, 02:40:32 AM »
Yes, that is what I was referring to as the pilot jet.  It's the closest thing I see to a pilot jet!  It is pressed in, doesn't look like it's designed to be removed.  However, I'm sure you could get it out if you wanted too!  Getting it back in may be a different story!
Re: my zx50 issues
« Reply #248 on: May 14, 2010, 02:42:16 AM »
...got me a big hammer...mhhmmm...
thebatman
Re: my zx50 issues
« Reply #249 on: May 14, 2010, 02:52:39 AM »
ill just be dam.. shaka i bow to you, ur right, i still had the main jet (shop kept rest) from the ORIGINAL carb when she was real punny, (you all have helped tremendisly), and it is a 90 jet..i took a presision handheld drill bit kit and reemed the hole out, seemed to be same size at time but was told bigger and sh**, these bits dont have the sizs, guess to small....lmao
"THE BAT"MAN...
Says:
Re: my zx50 issues
« Reply #250 on: May 14, 2010, 02:57:14 AM »
The conversion shows 163.5 PSI. so you were good when that 11.5 reading was taken. I would strongly suggest going up 1 jet size from whatever is in there now. There are tiny #'s stamped into the jet. If yours dosen't have them, you can bring it to your local guy to have him measure it for you. A little xtra fuel is better than too little
Re: my zx50 issues
« Reply #251 on: May 14, 2010, 02:59:56 AM »
...im finding that a lil extra fuel on the main can work out to be beneficial through mid throttle, in relation to power available...
« Last Edit: May 14, 2010, 03:03:12 AM by wordslinger »
Re: my zx50 issues
« Reply #252 on: May 14, 2010, 03:03:15 AM »
It's easy to tune it back out using the needle. Getting the wot is the most important bit too me
Re: my zx50 issues
« Reply #253 on: May 14, 2010, 03:04:16 AM »
...i couldn't do that with my original carb...needle wasn't adjustable....
..and that vid you posted the other day helped me see that...
thebatman
Re: my zx50 issues
« Reply #254 on: May 14, 2010, 03:09:42 AM »
"THE BAT"MAN...
Says:
