what up shaka?.... ok this may b a touch long, sorry.. well this a.m after the (4 sake of argument retest)..i did index the plug and i did turn the mix screw counter 1/4 turns.. i rode about 70miles today and I WOULD SWEAR it was different, carb actually sputtered couple times, i used sum oil too, bout 3-4oz today!! gotta be to much..and i think it was a bit slower and top end was "flatter"...... i have A jet from previous carb. i "cleaned" this jet supposedly to big, i thought it was gonna be same size but guess not?? idk, it was clean tho..lmao.. i tried to use same size to clean buuuut.. how do i know if it is to big?? figured id throw it in.. y is spacer hole bigger than intake & carb hole??.. guess i have to do another set of chops?? what will it look like if sh**?? i have only redone stock with new piston, rings, gaskets, cleaned cyl walls, different oem carb, technigas exhaust on the engine....(springs, rollers,tires,as of today: getting sids var, all new springs & rollers, want reed cage)
