what up guys? not sure if you wanted to know. been playing with cvt some.. you will not believe this, i think alot of my rpm problem was in the spring sortof. the ncy springs are 1-11/2 coils longer than malossi springs BUT, the "torsion washer" was on the side of the clutch NOT the pulley side, changed that got rpms back. also got screwed on my new clutch and bell. supposed to be polini but the clutch is actually a adige an bell is polini(dont fit). so i have 7.5malossi rollers, a ramp plate(until var gets here)--malossi white contra w/1500malossi fly springs, adige clutch, gates performance drive belt, 130/70rr,120/70ft tires(kenda) technigas next r chrome exhaust, removed rear rack & center stand(less wieght), eruo lights, chrome handgrips. (want a malossi reed cage but not sure if a waste).. next plan is rejetting carb or bigger carb, reed cage. want to learn portin since gonna run stock jug/head to increase sumthin.i can tell i am a bit flat at wot(carb?)anybody lookin for polini bell & air 4 zuma/vento
