That was one of the first things to do in one of those two cycle tuner books. Setting all the tolerances to spec. Basically "blueprinting" the engine. I can tell you for a fact that Blueprinting does as much for ANY engine as any other mod you can do. If you have access to a machine shop, and are VERY good at math/engineering, you can sometimes double the rpm's an engine can turn, and gain as much as 10% more HP, and torque. Us Buffalo eaters, would rather cut metal off until it is tighter, and tougher than it was from the start, but imagine if we had all the tools, and time to correctly build a 13'000 rpm 20hp 50cc based engine! Most 125cc engines cannot come close to those numbers. This is my very long way of saying the BATMAN has grown beyond all expectations!!! The squish is as good a place to start as any... Rock on Bro!
