I don't think I ever posted pics of my leak-down tester. You may be thinking of my compression tester. You can't just go buy a leak-down tester either, it's gotta be made. Actually, I take that back, Josh at SI sells them, but they aren't cheap! From the pics though, I'd say you do have a leak. It may also be coming from the cylinder base gasket. Have you tried spraying carb cleaner in that area while idling to note any changes in rpm? I'll try and get some pics posted up this weekend of the leak-down tester.
