Author Topic: my zx50 issues  (Read 109546 times)
Re: my zx50 issues
« Reply #765 on: August 22, 2010, 10:55:47 PM »
..lol..i like it...keeps me in high revs...
art
Re: my zx50 issues
« Reply #766 on: August 22, 2010, 11:00:52 PM »
 HA! Thats usually an air idle adjustment,If you don't have an air leak or fuel supply problem   :D  ;D  ;)
thebatman
Re: my zx50 issues
« Reply #767 on: August 22, 2010, 11:39:16 PM »
so i guess its back to square 1.. ::) :'(
"THE BAT"MAN...
Says:
Re: my zx50 issues
« Reply #768 on: August 23, 2010, 12:14:46 AM »
...dang...where's the second square...
thebatman
Re: my zx50 issues
« Reply #769 on: August 23, 2010, 12:19:50 AM »
i know thats right.. :D :D :D    wonder that myself.. :-[
"THE BAT"MAN...
Says:
art
Re: my zx50 issues
« Reply #770 on: August 23, 2010, 02:39:13 PM »
 Ha! don't worry just keep an eye on that plug!
thebatman
Re: my zx50 issues
« Reply #771 on: August 23, 2010, 02:51:55 PM »
well.....i have vaccum.. ;D ;D    took tank back off this a.m..flushed it out(filter had sedement already)..cleaned petcock, FINALLY got vaccum back..didnt push it. :D  put all together, AND added my first dose of seafoam to gas tank and oil tank.. ;D ;D ;)     will do a quick chop to check plug..thinking of putting a shim in needle today..(with rereading/guidance from you all. ;D ;D ;))         also gonna throw in 5.7s, think id rather be to low as to high.. ??? ;D  least rpms will stay put till i can get some 6s..
"THE BAT"MAN...
Says:
art
Re: my zx50 issues
« Reply #772 on: August 23, 2010, 03:21:38 PM »
 Cool  8)  Don't you feel better allready  :D  With your porting you may be moveing more air so plug chops deffinetly
thebatman
Re: my zx50 issues
« Reply #773 on: August 23, 2010, 04:15:38 PM »
well i ASSUME the vaccum correct..when i pulled on vaccum, could hear diaphram going up and down..when blow into fuel, its blocked..soooooo, i assume anyway. :D  hadnt started it yet............i need to port the intake since im to busted these days to order nice ones.. :'(   maybe porting intake/ported reed cage also w/a shim in needle...maybe thatll help some, idk... hoping the vaccum helps the takeoff issue.... thats driving me absolutely nuts there now...... >:( >:( >:( >:( ;)
"THE BAT"MAN...
Says:
thebatman
Re: my zx50 issues
« Reply #774 on: August 23, 2010, 10:05:45 PM »
ok check this out...plz.....this has happened numerous times..when i FIRST start her up(warmed just a min),and take off she is almost there..take off better, accel better, top better..BUUUUUT..when i take a short ride and shut it off(store,chops,etc.) and start it back, (still warm anyway),the take off is worse..up to 20mph/30km take off sh** slow/sluggish then hits and gone...even put in 5.7s today(liking these sum,hills rpm better,top great,rpms better ;D )....i have experianced this tho with multiple weights....start up,go, better...short ride, shut off, start up,go worse up to 20mph
"THE BAT"MAN...
Says:
Hoolander2
Re: my zx50 issues
« Reply #775 on: August 24, 2010, 03:04:08 AM »
Let me comment here for the first time now since I am an old two stroke guy.  It sounds to me like you've gotten it real close to dialed in.  But, Bat man, 2 strokes always have run better when cold.  MUCH better.  That's why most racers went to water cooling long time ago and some street 2 strokes got water cooling later.  It's just the nature of the beast and you should expect a lot more pep when it's not fully warmed up.  Less when it is.
Gotta work around that at all times with your tuning.
Hoolander2
Re: my zx50 issues
« Reply #776 on: August 24, 2010, 03:05:48 AM »
Let me be real clear.  You may already have it dialed in as good as can be.  Just gotta expect that drop off when warmed.
art
Re: my zx50 issues
« Reply #777 on: August 24, 2010, 03:15:57 AM »
This is tru to some extent but think about it,when cold it is running for 10 points please!!!! diing diing diing!  RiTch! so a little clue as to what you need to do  ;)
thebatman
Re: my zx50 issues
« Reply #778 on: August 24, 2010, 10:43:49 AM »
hey hoolander...thanks for the reply.... where ya been... ;D  well sh**, i was hoping it wws something fixable, but at aleast its not me... ;D   art, you bro, have me a bit lost i think..ill reread your post buttt.....
"THE BAT"MAN...
Says:
art
Re: my zx50 issues
« Reply #779 on: August 24, 2010, 04:38:24 PM »
  The wormer your motor gets the leaner it runs so to take advantage of it I would say go to even larger JETS!  ;)
