Author Topic: my zx50 issues  (Read 109526 times)
thebatman
Re: my zx50 issues
« Reply #840 on: September 01, 2010, 01:19:12 AM »
everytime i DONT TIGHTEN the piss out of that nut, minutes after i take off the drive face is rubbing the kick ratchet, so i have to PUSH back.
"THE BAT"MAN...
Says:
sidthesloth
  • Kymco ZX50
Re: my zx50 issues
« Reply #841 on: September 01, 2010, 01:22:38 AM »
This is out of my depth, but, if the seals are worn, once you get the engine running, it should stay running, starting would be the problem?
art
Re: my zx50 issues
« Reply #842 on: September 01, 2010, 01:23:21 AM »
The test i'm talking about is when not starting(on the plug) It was not constant for me until dead. If you have spark now will it start?
  Don't worry about the crank Just thinking outloud   ;)  my bike still runs I just can't go 100 miles an hour the way it is  ;D
Re: my zx50 issues
« Reply #843 on: September 01, 2010, 01:23:59 AM »
..i tighten the piss outta it with th ratchet...
Re: my zx50 issues
« Reply #844 on: September 01, 2010, 01:25:07 AM »
..dammit..me neither....
sidthesloth
  • Kymco ZX50
Re: my zx50 issues
« Reply #845 on: September 01, 2010, 01:27:14 AM »
I can, just not on my scooter. ;)
art
Re: my zx50 issues
« Reply #846 on: September 01, 2010, 01:30:16 AM »
  Maybe my goal is unrealistic  :D  but damn i know i was 3/4 of the way there ;)
sidthesloth
  • Kymco ZX50
Re: my zx50 issues
« Reply #847 on: September 01, 2010, 01:34:49 AM »
Yeah, but the higher you go, the harder each small increase gets.
Re: my zx50 issues
« Reply #848 on: September 01, 2010, 01:37:14 AM »
..dunno if it's so unrealistic or not...maybe, but 80 is definately obtainable....
..i have a stock 01 that hit 65+ out of th box with just an air filter and a jet..
...i mean.....
art
Re: my zx50 issues
« Reply #849 on: September 01, 2010, 01:46:05 AM »
  Yep all looked to be on track than one thing after another.But the dieing thing and the play in the crank showed up around the same time, Once i really pushed it it got worse. So not going to push this one any further with out a new crank, bearings and seals. I think the rest is in line for a good show though.
thebatman
Re: my zx50 issues
« Reply #850 on: September 01, 2010, 02:04:54 AM »
hey art, to answer your ?....went out, spark pretty and blue(checked again),put plug in, no start...finally started after about 25 kicks.....hmmm??, youd think fuel?? maybe, i guess. :D :-\
"THE BAT"MAN...
Says:
art
Re: my zx50 issues
« Reply #851 on: September 01, 2010, 03:56:12 AM »
  What im trying to say is it's intermitent so do not pull the plug when it's happening,just the cap and put another plug in to the end of the cap at that moment to guage your spark.
  If you have spark at that time then you need to test for fuel. Pull your airbox off and give it a shot of  fuel through your carb if it fires right up than you have a fuel issue. from there its vacuum or its blockage. as it seems you have all ready tested for air leaks. It's back to basics. Must have spark,fuel and air to run. If you are missing anyone of these it's no go
« Last Edit: September 01, 2010, 03:58:06 AM by art »
sidthesloth
  • Kymco ZX50
Re: my zx50 issues
« Reply #852 on: September 01, 2010, 07:22:57 AM »
G'day batman, I am clutching at straws here, but, it may be worth a try. In remembering one of zombie's posts, he spoke of the cdi derestriction being a short, and in running in that rev range you risk burning out the cdi. If you are running your stock one with the rev limiter bridge in place, I wonder if it would be worth removing it for a test run, just to see what happens. I realise it may well be something else but as it costs no money it may be worth trying. If it doesn't change, at least you haven't spent any money and you can rule that out as a possible cause. as I said, it may not be it, but maybe worth a try, just thinking.
thebatman
Re: my zx50 issues
« Reply #853 on: September 01, 2010, 11:45:44 AM »
good morning sid....it does seem to jar my memory about that...just undo the splice????, how do you know????  if she goes back to 34 mph it still works???....
"THE BAT"MAN...
Says:
sidthesloth
  • Kymco ZX50
Re: my zx50 issues
« Reply #854 on: September 01, 2010, 01:19:25 PM »
I was thinking of seeing how she runs at wot over a distance, if it is good, problem found, if not, no money spent and search goes on. I am just suspect about the cdi with this type derestriction. This must be frustrating for you being your only transport.
