Author Topic: my zx50 issues  (Read 109501 times)
art
Re: my zx50 issues
« Reply #915 on: September 16, 2010, 04:25:36 AM »
 Ha! didn't think that would be a problem,I was worried about the cap not working. I'll be back with some pics for ya.
art
Re: my zx50 issues
« Reply #916 on: September 16, 2010, 04:47:26 AM »
Here's the intake side This is center to center on the mounts and the opening is just a hair under 11/16
thebatman
Re: my zx50 issues
« Reply #917 on: September 16, 2010, 06:06:44 PM »
that looks similar for sure..the bowl is different tho....
"THE BAT"MAN...
Says:
art
Re: my zx50 issues
« Reply #918 on: September 16, 2010, 07:37:59 PM »
 As long as it fits It should be fine. The cap was what i was concierned about.
sidthesloth
  • Kymco ZX50
Re: my zx50 issues
« Reply #919 on: September 16, 2010, 07:40:43 PM »
Just check the cap size.
thebatman
Re: my zx50 issues
« Reply #920 on: September 16, 2010, 08:04:22 PM »
measuring the cap..i.d is .670in..just under 11/16..o.d is .815in.. 13/16...         on the rollers, belt tug/jerking needs lighter....slippage needs heavier correct???????.....
"THE BAT"MAN...
Says:
sidthesloth
  • Kymco ZX50
Re: my zx50 issues
« Reply #921 on: September 16, 2010, 08:10:03 PM »
I dont know anything about belt tug, I thougt it was from slipping.
art
Re: my zx50 issues
« Reply #922 on: September 16, 2010, 08:33:56 PM »
That is about right bat unless springs are way off that should work. I re measurd the carb cap it too should work for you . The 15/16 I gave you was from outer thread to outer thread and a little generious to give you an idea
thebatman
Re: my zx50 issues
« Reply #923 on: September 16, 2010, 08:37:24 PM »
hmmm....i did try to measure the inside threads...may just work art...
"THE BAT"MAN...
Says:
thebatman
Re: my zx50 issues
« Reply #924 on: September 16, 2010, 10:20:54 PM »
i just thought.....i never asked but one leak was my head gasket..what could cause the gasket to blow???... everything??. :D
"THE BAT"MAN...
Says:
thebatman
Re: my zx50 issues
« Reply #925 on: September 29, 2010, 01:35:00 PM »
what up fellas? sorry i not been here... gave some a break tho i guess. :D    anyway, remember a few weeks ago i had a crack in my pipe?? well it got fixed, looked yesterday cause she seemed to be chockin somewhere... i bought a filter and took out packing in pipe just to see.... MY DAM PIPE IS CRACKED AGAIN IN THE SAME DAM SPOT!!!!!!!!!!   now the ? is:........ HOW? sh**ty welds??? or a techy stuff with the soundwaves,etc..?? OR is being on the light mix ring STILL TO LEAN for the pipe and just getting hot???   was fine, all was well, started losing rpms uphill, real sluggish, cleaned var,rollers. still done it. removed packing in pipe, saw the crack.................. AND A GOOD? FOR YA; HOW IN THE HELL CAN YOUR PIPE GET QUIETER WHEN YOU REMOVE THE PACKIN??? SHOULDNT IT GET LOUDER???
"THE BAT"MAN...
Says:
Hoolander2
Re: my zx50 issues
« Reply #926 on: September 29, 2010, 04:22:39 PM »
Hey, Batman.  The thin steel gets so hot when it's welded that it gets brittle all around the new weld. It'll keep happening.  I'll bet if you look close, the new crack is not exactly on the weld but right next to it.  Only real solution is to come up with rubber mounts or something to dampen vibration. And even then might still have to get new pipe. . .  >:(  Maybe try to find one made of thicker steel.
Maybe a welder who knows how to keep things cool with a cooling gas during weld could prevent that.
Maybe got louder with packing cause exaust was being more forced out of crack?
art
Re: my zx50 issues
« Reply #927 on: September 29, 2010, 06:14:59 PM »
  ???  Forgot which pipe your running. The 4t's are usually pretty strong. Maybe try a sleeve or patch over the weak link.
Re: my zx50 issues
« Reply #928 on: September 30, 2010, 02:46:53 AM »
..i'm a fairly decent welder...and i had a fit re-welding my muffler back together after i cut it open that time...
..i used .030" stainless wire...which was too big, but all we use..
..i couldn't imagine trying to weld the pipe....
671zx
Re: my zx50 issues
« Reply #929 on: October 05, 2010, 03:54:57 AM »
where did you get the intake manifold and the boyesen reeds? Also, do you have a part # for the gears? Ive been trying to find gears for a while now.
 Thanks
