Author Topic: Installing new exhaust  (Read 2624 times)
sw19
    • Stan Wagner's Portfolio
« on: February 18, 2010, 02:13:51 PM »
Has anyone installed an exhaust pipe on their People? Is access to the bolts attaching to the engine easy to get to or, do I have to remove any body panels?
-Stan
Re: Installing new exhaust
« Reply #1 on: February 18, 2010, 10:17:48 PM »
There may be a service manual here. If not surf canyon as a search engine can get you to one.http://www.timtaylor.net/Scooter/Manuals.htm
smoke eater
« Reply #2 on: February 19, 2010, 04:34:34 AM »
I intalled a new exhaust on my P150 last year.  If you go to the thread titled "Jet size" there are a couple of pictures there.  The exhaust bolts do not require you to take off any body panels, but you will have to lay on the ground a bit.  They are a standard size (10mm I think) but are pretty long.  One tip, there is a metal gasket that is part of the system, make sure you get that and if it is not damaged, you can use it for the new exhaust.
Smoke Eater
sw19
« Reply #3 on: February 23, 2010, 10:17:01 PM »
Thanks. All I had to do was remove the small panel down by your feet. Gave me a view so I can see the two exhaust bolts. Entire job took 10 minutes.
-Stan
« Reply #4 on: February 24, 2010, 12:30:48 AM »
Very nice! What did you replace it with? Stock?
sw19
« Reply #5 on: February 26, 2010, 08:11:43 PM »
Stock pipe.
-Stan
CoolSoupy
« Reply #6 on: July 03, 2012, 12:15:10 PM »
Did you find an aftermarket exhaust? Kymco is too expensive.
CoolSoupy :-[
