Author Topic: synthetic oil  (Read 4709 times)
axy
Re: synthetic oil
« Reply #15 on: March 30, 2010, 07:44:24 AM »
As a middle ground, you could add a finer screen to inside of the factory screen for the next oil change to ensure you can filter out  more of the nasties - and then change over to the factory screen for the balance of its life.
If continue to get largish metal chunks in your oil after break-in +one oil change ...you have problems bigger than the gauge of the mesh in your oil filter.
I`ve never seen anything in the OEM screen of Agility in 15.000 kms and People in 9.000 kms...
Kymco Agility 125 2008
TechGuy
Re: synthetic oil
« Reply #16 on: March 30, 2010, 07:50:24 AM »
I bought mine used but have never seen anything in mine and i have checked it everytime except this last change 9at 1130 pm the night before a 300+ mile ride).
I now have 30,000 km on my P250.
as to the OP... I have not really felt the need to go to a synthetic oil.  The P250 has an oil change indicator and when I gets red, I buy a quart at Wal-Mart and change it. A straight oil change takes more time for set-up, draining, and clean-up than the actual work. I typically use the Delo or Rotella 15W40 as I understand diesel engine oils don't have the "gas-saving" additives in gas oils that don't work well in the high-temp m/c engines.  I know the oil is dark when I change it every 2,000 km or so. CVT scooters do not have wet clutches like geared bikes and do not require the m/c specific oils some m/c require as the gas saving additives can ruin a wet clutch. I may be wrong , but this is what I have been doing and i am sure this is better care than many third world riders do for thier scoots.
ispud
Re: synthetic oil
« Reply #17 on: March 30, 2010, 01:06:01 PM »
not getting "large metal chunks", but getting a very fine grit of some sort - gleams like metal.
scooter is just over 2k miles - probably changed oil about 4 times since new - will taper off frequency in the future.
