Author Topic: Different Size Variator  (Read 37751 times)
thebatman
Re: Different Size Variator
« Reply #105 on: July 21, 2010, 12:42:39 PM »
got a ? about those roller tunning kits...... i looked at several diff ones but they ALL look like they are for thhe 3 roller setups....saw like a 3-9g 18pk...thats only 3 a set...same wit 9-14g...even saw a dr pulley roller kit but looks like a 3 deal...       am i missing something..(like those prices vs. the $17 a pop..lmao)
"THE BAT"MAN...
Says:
« Reply #106 on: July 21, 2010, 01:06:12 PM »
..i have two sets..each are 6 roller setups...
..they're around 30 bucks a piece...
..between the two, they range from 4-9 grams...
..don't recall what brand, but when I get home i'll check that out and let you know...
« Reply #107 on: July 21, 2010, 01:10:34 PM »
"http://www.stage6.fr/catalog/stage6-04-variator-24-0.html"
..these are what i have....the set on top and the one to the lower right..
« Last Edit: July 21, 2010, 09:26:56 PM by wordslinger »
sidthesloth
  • Kymco ZX50
« Reply #108 on: July 21, 2010, 02:47:18 PM »
I wouldnt use the 3 roller ones because the collective weight is less than with 6. I used cheap ones from scooter assassins to work out what weight I wanted. But then I changed the torque spring, now I need heavier sliders.:)
art
« Reply #109 on: July 21, 2010, 05:37:09 PM »
http://www.provoscooter.com/ruima-variator-roller-tuning-kit-16x13mm.html .I'm in the same boat sid but these are the ones I used.
thebatman
« Reply #110 on: July 21, 2010, 09:09:41 PM »
sweet, cool beans thanks dudes...i did look at provo and those looked like the 3rollers...maybe im just blind, cant see sh** wit this phone......             ok this var is starting to get on my nerves....im thinking this extra weight is throwing me off....rode wit the 8.5/1500s today....takes a long time to get in the power band,(if in it, runs great), from take off..up to 30 is SLOW(bit humid here today)..maybe i will HAVE to go light as hell to compensate for the extra weight???    any ideas now????....lmao
"THE BAT"MAN...
Says:
art
« Reply #111 on: July 21, 2010, 10:04:31 PM »
once again did you try 3 7g and 3 7.5g I think that was going to be your spot???
sidthesloth
  • Kymco ZX50
« Reply #112 on: July 21, 2010, 10:41:48 PM »
Dont use different weights, the 3 7.5s will work the variator and the other 3 will just rattle around. 8.5 is too heavy, try somewherde around 5 or 6, especially if you are on the stock torque spring. If the variator is too heavy you will need less weight somewhere. Remember, heavy weights close the variator quicker.
« Last Edit: July 21, 2010, 11:30:11 PM by sidthesloth »
art
« Reply #113 on: July 21, 2010, 10:47:28 PM »
Hey sid it will work fine for tuneing not suggested for a daily rider,worked great for my tune process till i outgrew my test kit  ;D  It let me know what wieght to perchase or in our cases modify to.No ill affects will flatten them rollers quik if run to long.
« Reply #114 on: July 21, 2010, 10:54:51 PM »
...yup, that's the point of the different weights of the variator tuning kits..
..so you can really dial it in.....
sidthesloth
  • Kymco ZX50
« Reply #115 on: July 21, 2010, 11:34:07 PM »
Nope, I still don't get it, if you try 3x7s and 3x7.5s, which ones do you use if that configuration works?
I have yet to see rollers in the 0.25 gram range and if they were out there, how accurate would they be?
« Reply #116 on: July 21, 2010, 11:36:17 PM »
..yea, but i run 4.7 grams in my a50...with the stock drive face, ncy variator (malossi was better)
..it llloves them......
« Last Edit: July 21, 2010, 11:39:00 PM by wordslinger »
art
« Reply #117 on: July 22, 2010, 01:05:27 AM »
you can mod the weights if it comes down to it,you will need scales and a dremmel for light changes or if your lucky the right drill bit can shave the perfect amount off,my bro in laws people after some mods we did ran best with a 7.30g set .He just happened to have a bit that allowed us to drill the centers out a little bit and wieghed each one and were with in .001 of each other not bad in the back yard with a hand drill acouple of beers and what the hell attitude the 7.5 wer'nt working any way.Try it ya'll like it Ha!
« Reply #118 on: July 22, 2010, 01:08:23 AM »
..i quarter gram does make a difference....
...just as a mm difference in the drive face or variator, or a cpl in the belt....
..damn...
..tuning...
..it'll never end!!!....
thebatman
« Reply #119 on: July 22, 2010, 01:20:10 AM »
well i tried 6.5 w/stock spring, 1500 flys....ehhhh....today i have the 8.5 w/1500s.........i dont have any 6s or 9s...i had thought of a 7.25 before actually....lmao..(with oem var).. guess i need to try and get me one of those roller kits.                                     do like that my belt goes tp the very edge of the var now unlike the oem which lacked about 2-3mm to reach edge...
"THE BAT"MAN...
Says:
