Author Topic: Bar end weights?  (Read 3099 times)
Cortez
    • My flickr account
Bar end weights?
« on: March 15, 2010, 02:38:42 PM »
Anyone know how heavy the stock/OEM bar-end weights on the Agility 125 are?
I could use some bigger ones, but have no idea where to look.
Ebay?
Are they all universal or..?
I don't need anything fancy, just more weight, as cheap as possible.
'08 FZ6n S2 ABS
axy
Re: Bar end weights?
« Reply #1 on: March 15, 2010, 03:31:30 PM »
Agility 125 does not have handlebar weights.
Kymco Agility 125 2008
« Reply #2 on: March 15, 2010, 05:12:05 PM »
..okay, enlighten my...
...what are handlebar weights for??
jprestonian
    • a scooter called wanda
« Reply #3 on: March 15, 2010, 06:04:01 PM »
On the Agility, damned little, I'd say. Its "weights" are light plastic inserts, no?
The weights help to dampen sympathetic vibration/oscillation in the steering circuit.
axy
« Reply #4 on: March 15, 2010, 06:19:27 PM »
On a number of motorcycles, depending on the suspension and steering setup and angles, when you install rear top case, the shimmy action of steering/front wheel increases if you have stock handlebar weights. Most serious top case manufacturers provide heavier weights to be mounted instead of stock ones. For example, I had original Beverly topcase and it came with heavier weights, so did Givi on Kawasaki ZR-7S,
Handlebar weights also lower vibrations transmitted from the engine onto steering wheel, especially in case of thumpers and 2-cyl bikes, thus making the ride considerably more comfortable.
However, Agility is not affected by this, especially not with 25l cases, and does not have stock weights either.
« Reply #5 on: March 15, 2010, 07:05:04 PM »
..lil plastic caps...that i no longer have due to once..getting run off the road.......then the time my scoot got knocked over at work...lost the other one...
Cortez
    • My flickr account
« Reply #6 on: March 16, 2010, 06:47:02 AM »
It sure is affected by my 35L topcase, and while it's considerably less of a problem with the 26L case,
the front would still shake from time to time.. so I figured I'd add some weights..
'08 FZ6n S2 ABS
axy
« Reply #7 on: March 16, 2010, 09:58:06 AM »
You can try but probably you will not fix it that way and it will still shake.
I had literally half a kilo of end bar weights on Beverly and it still did not fix the shake (yet I had both top case and two hard plastic side cases).
Cortez
    • My flickr account
« Reply #8 on: March 16, 2010, 12:06:26 PM »
Great.
It's interesting to see the scoot sit on it's front wheel while on the center stand without the top case, and
shift to the rear wheel as soon as I put the top case on.. even when it's empty.
I know most (all?) scooters have the front end a lot lighter then the rear, but Agility's front is so light
I'm amazed how the front tire manages to grip the road while cornering  ;D
It would probably benefit from bar end weights.. or any kind of extra weight on the front end (as low
as possible).
I'll let it be for now.. it's not a big problem with the 26L case, and 35L works too if I'm not going over
80km/h.
'08 FZ6n S2 ABS
« Reply #9 on: March 16, 2010, 01:21:42 PM »
..my A50 front end only shakes when i am holding on with just one hand...
..wonder if bar weights would correct that....
Cortez
    • My flickr account
« Reply #10 on: March 16, 2010, 01:25:32 PM »
It would help.. no one knows how much though, as it might be the front tire's fault too.
'08 FZ6n S2 ABS
axy
« Reply #11 on: March 16, 2010, 01:37:04 PM »
I know a number of bikes and scoots whose front end shakes/wobbles if the steering is not held tightly with both hands - new bike, no problems with steering, configuration, tires.
Their geometry is done that way and that`s it.
« Reply #12 on: March 16, 2010, 02:28:40 PM »
..itsa new tire...and it's done it since day one, even with the original tires...
Cortez
    • My flickr account
« Reply #13 on: March 16, 2010, 06:06:13 PM »
Most tires in this segment of the market are usually not even round.. so.. no surprise there  :(
'08 FZ6n S2 ABS
axy
« Reply #14 on: March 16, 2010, 07:40:23 PM »
Most touring tires, even sport touring tires are like that. You can get 1300 cc naked with the same tire curvature as on Agility 125.
