Author Topic: stock scoot top speed  (Read 8139 times)
Kimcofan
Re: stock scoot top speed
« Reply #15 on: March 23, 2010, 05:29:01 PM »
Yeah dont worry too much there is a lot of helpful imput on the site and you might have a problem and just hearing everyone talking you will go DUH and a light bulb will appear over your head and you'll figure it all out!
sticlistul
  • Sex, Scoot and Rock 'n' Roll
« Reply #16 on: March 23, 2010, 05:58:29 PM »
I've done some searching and i will need a standard  or stas of 0.4mm for valve adjusting, put in the gap and adjusting until I can remove the standard , in this way i can't go under 0.4 and there's no risk .
« Reply #17 on: March 23, 2010, 06:00:43 PM »
.04mm not 0.4mm
sticlistul
« Reply #18 on: March 23, 2010, 07:00:43 PM »
Other question , in the attach picture is a hose marked by me in red , from that hose stream a brown substance with a foam which looks like cappuccino foam , it doesn't stream much just what is in that hose , it is normal that ?
« Reply #19 on: March 23, 2010, 07:45:18 PM »
...pic???
..see no pic...
 ;D
sticlistul
« Reply #20 on: March 23, 2010, 08:37:12 PM »
i am verry sorry i forgot.
« Reply #21 on: March 23, 2010, 08:39:32 PM »
...yeah, that's just a condensate drain...you'll want to drain it every now and then...
..when you replace the stock airbox with a high-flow air filter it goes away...
 ;D
sticlistul
« Reply #22 on: March 23, 2010, 08:51:16 PM »
rain doesn't smells like gasoline , also at your stock air filter it happens to find leaks of gasoline in the air filter ?
« Reply #23 on: March 23, 2010, 08:52:57 PM »
...it come back into the chamber from the carburetor..
..don't sweat it...it's normal...
« Reply #24 on: March 23, 2010, 08:57:40 PM »
sticlistul
« Reply #25 on: March 24, 2010, 02:42:33 PM »
few updates =)) ,i've called my uncle to ask him what derestrct has done on the scoot (the scoot it's a gift from him ) and he told me just the boss from the variator is changed  ,he didn't touch the CDI ,now i have to take al 16 pages of topics to look at every cdi topics and see what I gave to do ... any pictures would hellp me very much ... i hope i will find some
« Reply #26 on: March 24, 2010, 03:05:34 PM »
  Derestricting your Agility CDI
« on: April 13, 2008, 06:34:35 AM » Quote
this allows you that your Agility runs 9000 rpm
just cut the CDI on a place shown on picture, there is a tiny copper wire which should be cut
Just be careful, do not cut too much
sticlistul
« Reply #27 on: March 24, 2010, 04:08:39 PM »
OK I've read enought tomorow i will do the cutting and see the changes when I go to faculty . Thanks wordslinger for information I hope that will go me up to 65 km\h . I hope I don't  forget to remove the tape off my air filter paper :))
« Reply #28 on: March 24, 2010, 04:37:10 PM »
...be SURE to remove that tape...i was still secretly suspecting your cdi all along...lol..
..you're gonna love it when you cut it!!!!...
..keep us informed of your progress!!
peace
sticlistul
« Reply #29 on: March 24, 2010, 07:54:50 PM »
yeeaa , I've done the cut it taked a minute... at 3 mm of cuting i've found it . I couldn't wait until tomorow so i've done it . i didn't ride the scoot but i've start the engine and i felt imidiately an increase of RPM . Tomorow i will see how fast it is . I'm not intersted to go very fast ,here in Romania even if the speed limit is over 60 km\h the roud don't let you to go faster :)) it's full of pits .
