Author Topic: Why do the People S 200 have a kick start?  (Read 5239 times)
Carol
  • Brainerd, Minnesota
  • Look me up on facebook !
« on: March 29, 2010, 04:29:24 AM »
 8)  Have tried to kick start the scooter just for giggles, and found it impossible for me to do.
 Are all kickers stiff or am I just a wimp?
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body. But rather to skid in broadside , thoroughly used up , totally worn out and loudly proclaiming "WOW, what a ride!!"
Shaka
Re: Why do the People S 200 have a kick start?
« Reply #1 on: March 29, 2010, 05:31:02 AM »
Having never personally kickstarted a People S 200 I'm not sure, I'm going with wimp though!  Just kidding!  I kickstart my ZX50 multiple times daily and it's easy.  I'm not sure if the larger engine is just harder to turn over, or you have something jammed up?  Does the lever move when you kick it, or can you just not get enough umph behind it?
Domo
« Reply #2 on: March 29, 2010, 07:36:45 PM »
When I had my battery issues last summer, I kicked started it many times. It was very difficult to depress. I needed all of my 200+ pounds to do it.  Even with that I would nearly exhaust myself with the repetitions needed to get it started. The first time I needed to do it I was stranded at work. A passerby who said he was an experienced motorcycle rider helped me out and had a difficult time as well and commented on how difficult it was.
« Reply #3 on: March 29, 2010, 09:54:55 PM »
It may be a combo of 2 things. The ratio on the 1/2 moon kick gear, and the auto choke not coming in when the scoot is warm. I found my 50 ALWAYS needs the manual choke ON to get a 1 kick start. As for the ratio of the starter gears there is really nothing you can do to change that.
axy
« Reply #4 on: March 29, 2010, 09:59:06 PM »
Kick starting Kymcos is very hard, but I like that because it gives a "solid build" feel to it.
Kick starting Italian scoots for example is much easier but it feels like you will break something.
Kymco Agility 125 2008
rgy
« Reply #5 on: March 30, 2010, 06:15:18 PM »
Zombie, you have manual choke on a zx 50???  how, where, not factory correct?  i use duct tape to cover the intake area
TechGuy
« Reply #6 on: March 30, 2010, 11:39:58 PM »
They took the kick start off several Vespas as they found they would not start them if the battery was too far gone -and- the if you used the kick start lever in the wrong way/nangle/place, it would crack the CVT housing face around the the starter shaft. Many have found the new cover and replaced their old one or have taken the lever off and covert eh remaining hole as it was useless 90% of time and break the cover the balance (%s are SWAGs)
« Reply #7 on: March 31, 2010, 12:29:23 PM »
..kick-start mechanisms should be kept lightly, but well lubricated for them to function smoothly...
..don't lube excessively, because you don't want it to transfer to the cvt...
..i removed my electric starter a long time ago, when it just would no longer work, and my dealer said KYMCO denied it as warranty becaue i had not been taking the scoot to a factory rep for service...
..i can, with a good glove on, start my A50 by hand with the kick-start...
Calothrix
« Reply #8 on: April 01, 2010, 01:31:27 AM »
Have tried my P150 a few times also without success.
« Reply #9 on: April 01, 2010, 01:50:39 AM »
For rgy: I have a Delorto carb. That was the first part I ordered!  For wvlady I forgot to post it is easier to listen/feel for the compression stroke on a 4t engine. You push the kick lever untill you feel the resistance of the valves closed, and then give it a firm kick. The idea is you are lining up for the spark to hit on the first bit of the kick, and not spinning the engine on a dead stroke. Same applies for all 4t engines.
« Reply #10 on: April 01, 2010, 06:56:45 PM »
...well put zombie!!
Cortez
    • My flickr account
« Reply #11 on: April 08, 2010, 02:25:36 PM »
I could have kickstarted my Peugeot 50cc scooter with my thumb  ;D but the kick-starter
on my A125 takes a bit of effort and it's rather hard to get it going using the kick-starter.
'08 FZ6n S2 ABS
« Reply #12 on: April 08, 2010, 02:43:37 PM »
..you might want to try adjusting your idle mix a bit...
Cortez
    • My flickr account
« Reply #13 on: April 08, 2010, 02:57:37 PM »
Why?
It literally explodes into life in milliseconds when I thumb the electric starter..
'08 FZ6n S2 ABS
« Reply #14 on: April 08, 2010, 03:02:40 PM »
Why?
..then don't worry about it...
