Author Topic: ..jet soldering..  (Read 929 times)
..jet soldering..
« on: March 29, 2010, 07:31:15 PM »
..that crap really works!!!
..THANX ZOMBIE!!.. I'll never buy another jet..you can custom-make your own size..
..first attempt, i knocked the jet off the burner..it fell into the tray below the burner, spilling molten solder and rolling the jet's threads all in that...well that was a lot of fun, and i couldn't scrape the solder off the threads, so i heated it again...(heat process goes really fast)..and threaded it into the holder while it was still hot...okay, that worked...
..second attempt..couldn't keep the stainless wire i was using straight...wanted a straight hole...said screw the wire, and just filled, cooled and drilled...
..so, now with the blown air induction, and catalytic converter outta my muffler, along with about 1/4 of the baffle, i'm at a 1.04mm diameter main jet...
..updates and pics to come...
peace
« Last Edit: March 30, 2010, 10:30:48 AM by wordslinger »
Re: ..jet soldering..
« Reply #1 on: March 29, 2010, 09:30:56 PM »
You've been a busy fella! I see 55 on the flat w/ a little left over...
« Reply #2 on: March 31, 2010, 08:41:56 PM »
..boy, don't i wish...lol..
..i think i'm going to have to open my slow jet...can't get rid of the lean idle condition...I think i've run the screw so far out that it ceased to make a difference...
..i tried to correct it by increasing the main, raising the needle, and i'm over 4 turns on my idle screw...and now, i'm a bit rich at WOT, which i don't like very much...takes away from my top end speed...
..i ran the fastest sustained speeds ever on the way home from work yesterday...then i did the overjetting...was a bit sluggish at WOT this morning....shouilda left the main alone...i was happy with it....
..so, it's back to the burner today!!!!
..Luckily, I have my newly assembled jet mod kit!!
« Reply #3 on: April 01, 2010, 01:23:37 AM »
You NEVER cease to amaze me Bro! Opening the pilot will help on accell. and de-accell. there  is not enough vacuum to get fuel thru the main w/ the throttle closed. I am waaaaayyy rich on the pilot, and it keeps things cool when the throttle is closed. I just hit it harder coming out of the bendies!
