OK... back to our regular program. In running thought mode....
I have the new exhaust assembly, small dents on the heat shield.. I will deal with it, basically been without a scoot for a month, i runs OK, loud, won't idle.. but OK.... it's the big night, fix my bike, yeah!...
...sitting on the driveway, tools by my side, loosen the rear muffler bracket bolt..ok..
front lower.. OK,
front upper bolt... wait.. no bolt... damn. lost bolt new a new one, what size is it, let's check... take the muffler off the bike (remember, the header pipe is broken clean off)
remove the header bolts and the 9 inch section of header pipe...garbage...
remove the muffler from the bolts, simple...
take the lower front bolt and thread it to the upper holes... what is that in the hole.. damn, the upper bolt snapped off three threads into the rear fork arm... that's f**ked
break out a drill and screw extractor, spend an hour getting frustrated and cannot get the broken bolt out of the hole.... f f f f f f f f
I now have an 8mm bolt threaded stud in an aluminum fork with a quarter inch hole drilled through it.
remove the rear fork arm from the bike,
Current status... fork at at the machine shop, new exhaust, sitting in a box in my front entry, stuck in a no-traffic-splitting cage, on a day where a car rolled over the center divide on the only street I can use to get to my office without a 10 mile detour.... arghhhh
damn... wrong thread.... F*CK!
