Author Topic: I HAVE MY 105 jet and by thursday I will have my K&N air filter  (Read 7378 times)
Shaka
Re: I HAVE MY 105 jet and by thursday I will have my K&N air filter
« Reply #45 on: April 16, 2010, 11:18:33 PM »
Sid, the stock gear ratio is 10.65:1.  The primary gear is 13/40, secondary is 13/45.
« Last Edit: April 16, 2010, 11:20:28 PM by Shaka »
sidthesloth
  • Kymco ZX50
« Reply #46 on: April 17, 2010, 12:19:59 AM »
Cheers mate, will get to it one day.
Shaka
« Reply #47 on: April 17, 2010, 02:50:21 AM »
All in good time!  I think you've got more pressing issues to deal with first! ;)
sidthesloth
  • Kymco ZX50
« Reply #48 on: April 17, 2010, 10:36:16 AM »
G'Day customx22, Shaka and zombie are helping me with a problem with my cylinder and shaka has asked about the power and rev range these v8 exhausts are designed for. I was wondering if you could help us with this please? All help is much appreciated. The thread is ZX50 in the general discussion section.
customx22
« Reply #49 on: April 21, 2010, 10:49:15 AM »
OK heads up the v8 i have is typhoon that for stock motor to 72cc but low end to  mid-range pipe.the other v8 is the hurricane this is a mid-top end pipe this is the one you should get.i have the typhoon.it a decent pipe.i just bought the ultimate pipe PG LONG mid-top high rev pipe will get you about 5mph more that v8 hurricane.ways to tell which v 8 you have is if you don't have the badge you have a typhoon and the one with badge is hurricane but also check the length of the pipe the hurricane is longer because it has a chamber in it.another thing if the exhaust hole is 33mm you have hurricane and if its 28mm you have the typhoon
customx22
« Reply #50 on: April 21, 2010, 10:51:31 AM »
where did you buy it from? how much was it $200 is the hurricane the one you want.the typhoon is not really that good but ok
sidthesloth
  • Kymco ZX50
« Reply #51 on: April 21, 2010, 10:59:52 AM »
G'Day customx22, mine has the badge, inlet pipe is 30mm and canister length is 275mm (from weld to weld). Any idea what rev range that would be? At a guess I would think mid range!? It would be nice if they would give a little info with these items. I must learn to ask more questions before buying.
