Author Topic: 09 Agillity stalls & hesitates  (Read 7910 times)
Kimcofan
Re: 09 Agillity stalls & hesitates
« Reply #15 on: April 04, 2010, 02:45:49 PM »
Is the only purpose of raising the carb needle for idle?
yankee doodle
« Reply #16 on: April 04, 2010, 02:57:47 PM »
 :-X Not yet gotta get through Easter first .Got it in mind . Thanks for the advise .Ill get back to you . Yankee . D
« Reply #17 on: April 04, 2010, 02:58:24 PM »
« Reply #15 on: April 04, 2010, 10:45:49 AM » Quote
..no, that's more for your accelleration and mid range throttle...
« Last Edit: April 05, 2010, 04:28:14 PM by wordslinger »
Kimcofan
« Reply #18 on: April 04, 2010, 03:05:18 PM »
Ok, I will get to that today too, you say it just needs to raised .25 Im sure I can find a washer about that
« Reply #19 on: April 04, 2010, 03:25:38 PM »
...that's what i did..but i had to file the washer to .025...and  you gotta file off the head of the needle some, and also the nylon retaining clip...
..that is, if your carb is the same as mine...
yankee doodle
« Reply #20 on: April 04, 2010, 08:51:56 PM »
 ??? IM GONNA TRY THAT  TUES ON MY DAY OFF . THANKS . Y . D
codger78
« Reply #21 on: April 05, 2010, 03:05:30 PM »
For what it's worth, small engines (whatever) are very sensitive to the use of old, stored gas that at this time of year might have been around since last fall (say).  Try some pump fresh gas and see if that helps.
Another thing is the (old) gas can that over a period of time accumulates sediment and moisture.  Check that out while you are at it.
OK...here's one more....I live in an area of tree trash and bugs and (you name it) drifting around in the air.  NEVER leave the gas cap off or unattended except to fill the tank.
borrowed dust
joeboy
« Reply #22 on: April 05, 2010, 04:18:38 PM »
the reason flash lights are called such is because the first ones made had a crank that you had to turn to charge the battery and it would only work for a short time and die then you would crank it it would light up then die ect so it would look like you were flashing light then when better batteries were invented people in the uk started calling them torches simply to distinguish a difference between the 2
and that concludes Dark's useless history lesson for the day class dismissed
Did you just make that up? thats simply not right.
http://www.ideafinder.com/history/inventions/flashlight.htm
http://en.wikipedia.org/wiki/Flashlight
The simple reason you call them something different from us in the UK is the same reason you call everything else different names than us, its because when we stopped ruling the USA the americans decided to go all out against everything British and call things by different names and do things the opposite to us, such as left hand drive cars and driving on the right not the left. calling a tap a fawcet a bumper a fender and all other stupid things like this. Before then we called everything the same.
« Last Edit: April 05, 2010, 04:35:11 PM by joeboy »
« Reply #23 on: April 05, 2010, 07:36:29 PM »
I thought it was because Brits. are just silly, and like cute names for things. Just kidding... Oh Oh, Got to run to the lew...
joeboy
« Reply #24 on: April 06, 2010, 12:58:20 AM »
Its loo by the way short for lavatory, and why do you say you want to go to the bathroom when you want the toilet? what if its just a toilet with no bath in it, what do you call it then...your use of our language is weird... ;)
« Last Edit: April 06, 2010, 01:01:45 AM by joeboy »
« Reply #25 on: April 06, 2010, 01:32:46 AM »
I was going to take a shower, sooo I should have said shoe? Or is it Shoo? Even spell check didn't have a clue..., Oh by the way the toilet w/ no bath is called the back door! I guess that would be the Doo... Peace Joeboy!
Dark13
« Reply #26 on: April 06, 2010, 02:25:55 AM »
no i didn't make it up its what i read in a book a long long time ago so maybe i remembered wrong but please never site wikipedia as a source
proud owner of a 2009 kymco agility 50
Calothrix
« Reply #27 on: April 06, 2010, 02:48:10 AM »
Maybe so, but you won't catch me eating spotted dick! ;D
ScooterCommuter
« Reply #28 on: April 06, 2010, 03:17:53 AM »
whats wrong with a steamed pudding with currants that usually served with custard?
« Reply #29 on: April 06, 2010, 03:34:23 AM »
The friggin NAME
