Author Topic: Speed Increase for Agility 4 50 stroke  (Read 2311 times)
tonys
« on: April 04, 2010, 09:54:24 PM »
I'm new to the forum and just bought an Agility 50 for my wife. She's laging on start up and top speed . We'd like to increase them just a bit. From what I've read here I'm assuming that I can by changing the weights to rollers , about 5.?, would help the acceleration? And that an unrestricted CDI would give it more top end, or possibly a larger carb jet ? Am I on the right track here? I don't necessarily want alot out of it just some to help her keeping up to the 2 strokeers.
Any help would be greatly appre3ciated.
Thanks,
Tony s
juice
Re: Speed Increase for Agility 4 50 stroke
« Reply #1 on: April 04, 2010, 10:03:11 PM »
4 strokes just won't keep up with 2 strokes , with the exception of wordslinger . And who knows what all he has done to his a50 . Good luck .
ScooterCommuter
« Reply #2 on: April 04, 2010, 11:39:52 PM »
bogging on pull away is pretty standard for a restricted A50. If you bought it new theres a chance that you found two parts in the seat box, a variator boss and a #82 main carb jet. Swap those out and you'll add a few mph. I havent bothered to do the cdi cut yet because just those two changes are good for an indicated 40mph on the flat. Just be aware that EVERY SINGLE TIME you strip down the carb (which you have to do to swap the jet) you're going to need to tweak the idle mixture and idle speed - and you'll have to do the same when the weather changes by any significant level as the seasons change too. Just read my little odyssey on the "tending to flood now the weathers changed" thread. I had valve clearance issues with mine and a potentially gunged up carb but the principle is the same. Strip the carb, retune the bike. Every time.
Kimcofan
« Reply #3 on: April 05, 2010, 01:21:46 AM »
72 cc big bore kit got me good!!!
kymconewguyontheblock
« Reply #4 on: April 05, 2010, 01:57:50 AM »
hey bought my agility two days ago the dealer did the to parts the boss and the jet its plenty fast on speed and pick up it tops and 45 mph I weight 140 so that might make a difference but I love my new scooter
« Reply #5 on: April 05, 2010, 03:20:14 AM »
Tonys, You are on the right track. The scoot is restricted by law, not by nature. Once you cut the cdi your engine will be free to rev, and you will gain 4-5mph on the top end. Lighter rollers will allow the engine to create the rpm's to get you there quicker. The larger jet will provide the fuel to allow all this to work. http://www.stadiumyamaha.com/pages/parts/viewbybrand/default.aspx   Go to the driven pulley section on this site, and you will see part#22105. It is another limiter in your scoot. The shoulder on that boss can be machined off for a few $'s, or you can replace it for about $35.00 for the same effect. Your scoot will do 45ish w/ no troubles. Don't mess w/ the 2 strokes tho. We have more secrets. Someone posted a link for AG/50 jets today for Kymcofan. I forgot to bookmark it, but the forum search will get you there. Welcome to the forum, and realize your wife will catch on when you try to tell her you just have to "check it out" one more time.
Kimcofan
« Reply #6 on: April 05, 2010, 03:58:48 AM »
And check it again, and again!!!
Always time to tune!
« Reply #7 on: April 05, 2010, 11:41:41 AM »
..i wish...still can't hang with those 2-strokes....but i'm holding onto their draft!!!
 ;D
« Reply #8 on: April 05, 2010, 07:47:36 PM »
The big difference is in a longevity contest the 4t will win out. Firing every other stroke does have it's own advantages.
« Reply #9 on: April 05, 2010, 09:42:10 PM »
...Welcome to the forum tonys!!!...
 ;D
peace
tundra
« Reply #10 on: April 06, 2010, 03:33:16 AM »
like Zombie said, and I admit 2t are a blast to ride!!!!!! but longivity, I'd have to go with 4t, little more tuning every-now-then, again longivity wise better.
