Author Topic: Dr. Pulley Sliders  (Read 3897 times)
Calothrix
Dr. Pulley Sliders
« on: April 07, 2010, 02:03:42 AM »
Has anyone installed Dr. Pulley sliding roller weights on their People 150?  If so, what size did you use and what effect did they have?  Thanks!
Partsguy
Re: Dr. Pulley Sliders
« Reply #1 on: December 08, 2010, 04:14:28 PM »
Yep, went with 14g and noticed an improvement over stock.
(Sorry for bumping an older thread, but didn't see anything else referring to it more recently)
Calothrix
« Reply #2 on: December 08, 2010, 06:08:18 PM »
Did you see an improvement in low end, mid-range and top speed or just 1 or 2 of these?  Thanks!
Partsguy
« Reply #3 on: December 08, 2010, 10:26:02 PM »
Sadly I never really topped out before putting them on.  Afterwards I got an indicated 63 at full throttle.  I do feel more acceleration at lower speeds and my mid range acceleration feels smoother pulling past 40.
Calothrix
« Reply #4 on: December 09, 2010, 05:48:17 AM »
I purchased a set of 13 g sliders last summer but haven't gotten around to installing them yet.  The scoot has been running so well that I haven't been to anxious to mess with it.
scooterchad
« Reply #5 on: March 04, 2011, 05:03:37 PM »
How easy or hard is it to switch these out? I've watched a few online vids and it doesn't seem entirely out of my skill set. Anyone with experience?
Hoolander2
« Reply #6 on: March 04, 2011, 05:27:13 PM »
You need either A: something to hold the variator while you loosen the nut.  There are special tools or some have made a simple tool.  I bought one at motorcyclesuperstore.com and had to modify it just a bit.  I think it was called a Motion Pro clutch holding tool. Works for holding a clutch on one side and variator on the other. Or order the Kymco holder.  Edit: on my Xciting, I have to install the holder to the variator, then wedge a piece of angle iron up against the frame and air box so the holder handle can wedge against that while I apply pressure on my breaker bar.
Or B: an impact driver -- either electric or compressed air powered.
In either case, a socket to fit the nut if you don't already have one.
Once you get the nut off, there's nothing else needed.  It all comes right apart.  The sliders must go in a certain way but pretty easy to see in the instructions that come with them.
One or two people have posted about not tightening the variator nut back up tight enough and had big probs when it loosened on its own so, get it TIGHT.
« Last Edit: March 04, 2011, 05:29:52 PM by Hoolander2 »
lifeisabeach
« Reply #7 on: August 04, 2012, 01:45:26 PM »
Bumping this old post..
Can anyone share their experience with changing rollers over to the sliders?  Whats best for a guy @ 200lbs - a bigger scooter? lol..
Calothrix
« Reply #8 on: August 07, 2012, 01:19:38 AM »
The OEM rollers in my 2005 People 150 are 18 mm x 14 mm x 15 g.  If you're considering going with Dr. Pulley sliders, I replaced my OEM rollers with 13 g sliders and they performed very similar.  If you're considering using sliders and you're looking for more low end acceleration, go with less than 13 g.  I have been very happy with the sliders.....nice smooth acceleration.
