Author Topic: loosen drive belt - b&w 250  (Read 1707 times)
lolektahor
« on: April 07, 2010, 05:11:35 AM »
hi all.
I own a 2007 B&W 250. from the moment I bought it (couple of weeks ago), I heard strange noises from the belt area. so I opened the cover and realized that the drive belt is a bit loose. but when the variator opens, everything seems to work fine. actually, the noises appears only while standing. I decided to buy a new belt, and so I did. but after replacing the old one, the belt is still loose.
whats next? should I replace the whole variator?
thanks for your help
Re: loosen drive belt - b&w 250
« Reply #1 on: April 07, 2010, 03:17:51 PM »
..you should at least take a good look at your variator and clutch...make sure both movable pulleys are free to move in and out as they should...
axy
« Reply #2 on: April 07, 2010, 03:29:21 PM »
hi all.
The belt looks "loose" by design.
Kymco Agility 125 2008
« Reply #3 on: April 07, 2010, 04:14:41 PM »
..what axy says is true, and these cvts do make a bit of noise, and if you've never owned a scoot before, it may just be inherent cvt noise that you hear...
..it may very well be that you have no problem at all..
..how does the scoot perform?
lolektahor
« Reply #4 on: April 08, 2010, 05:12:17 AM »
performance is great. the old belt looks like the original one and it looks good without any tears or rubbing.
the variator looks fine too, and moves smoothly. the spring also function okay.
I had a scooter before, and maintained some other in my life.
I don't believe that the belt is loose like that from the manufacture. I can see it knocking on the floor of the variator chamber (or whatever it calls), and there are black signs there. I can also hear this sound, which doesn't sounds really healthy.
thanks again
Shaka
« Reply #5 on: April 08, 2010, 05:18:58 AM »
Did you check to make sure the torque driver is fully closing when the engine is stopped.  The belt should be riding all the way to the top.
axy
« Reply #6 on: April 08, 2010, 09:22:48 AM »
thanks again
Usually, the "old" belt looks like new, if replaced within reasonable time, when there is no tearing.
However, if you take a measuring tool and measure width, you will notice that its width has decreased (so has the top speed and scoots acceleration, marginally).
If you want to check the belt, you need to measure its (cold) width and compare it to factory specs for replacement.
On my A125 after 12.500 kms the belt looked like new, but had just about right width to be replaced.
I know that belts on Kymcos usually last more than 22.000 kms before snapping, when you are left stranded and possibly with a damaged transmission, so it really does not pay off to be cheap on basic maintenance.
« Reply #7 on: April 08, 2010, 07:20:07 PM »
The other possibility is the torque spring inside the clutch. The oem springs do lose tension from the heat. Or it may have broken,, and is not working correctly. As the cvt componants cannot move, the trouble has to be there. A broken spring would explain the noise also. Let us know what you find
