Author Topic: paint job  (Read 1706 times)
Dark13
paint job
« on: April 11, 2010, 10:20:30 PM »
how hard is it to paint your own scoot and whats the best way to go about it? (i.e. taking all the plastic off or covering everything)
« Last Edit: April 12, 2010, 12:39:54 AM by Dark13 »
proud owner of a 2009 kymco agility 50
Dark13
Re: hey word
« Reply #1 on: April 12, 2010, 12:25:20 AM »
Rick0o07
Re: paint job
« Reply #2 on: April 14, 2010, 03:06:02 AM »
remove everything and paint it.... just make sure you do it right and take the time to prep..
I never painted a scooter Yet.. but paint cars all the time..
1. remove all parts thats  going to be painted..
2. sand with 600 sand paper.. so the new paint have somthing to hold too..
3. degrease it.. go to your local automotive paint shop and buy it there.. some parts stores might have it.
4. primer..if not.. just shoot color.. i use a gun.. works best..
.........when painting you can go single stage paint (color with clear build in)or
         two stage paint (shot color 1st then shot clear).
5. let dry min. 3 hrs to touch some times depending on weather might take longer.usually give
          24hr to put it back together..
Dark13
Re: paint job
« Reply #3 on: April 14, 2010, 03:15:20 AM »
thanks for the tip i think i will test paint a helmet first since it is a similar surface
Re: paint job
« Reply #4 on: April 14, 2010, 05:38:07 AM »
Being these scoots are plastic I always use Epoxy Primer. 24 hours to cure before sanding, and finish coats but WORTH IT.
