Author Topic: Could someone please explain how to set the time on the clock?  (Read 6109 times)
torgerskid
HELP -- I have tried holding down both buttons (expecting it would flash to set hr/min) but nothing seems to work. Owners manual has no instruction.
Could someone please provide clear instruction? -- Thanks in advance. (2007 People 150)
Bruno
Re: Could someone please explain how to set the time on the clock?
« Reply #1 on: June 29, 2008, 05:59:31 PM »
Bump.  I'd like to know too.
CelticCross
« Reply #2 on: July 09, 2008, 10:58:40 PM »
Push the bottom button to activate the mode, then press the top button to change the value.
Bruno
« Reply #3 on: July 10, 2008, 10:29:47 PM »
Thanks.
Yes, pressing the bottom button once puts it in date/time toggle mode, then pressing the bottom button again puts it in SET mode (cycling through month - day - hour - minute with each press of the bottom button).  As you mentioned, the top button changes the value.
« Reply #4 on: July 09, 2019, 05:10:39 PM »
Did not know myself ended up taking the battery out and putting it back in at noon. I don't think my bottom button is working.
Heads up a 357 battery will work if you leave out the plastic cap. Could not find a LR43 battery local.
