You first need to remove the exhaust and rear inner fender. Then you break the loose the big nut in the center of the rear wheel. I think it is a 24mm. I used a 15/16" socket, don't have a 24mm one. Once you get the rear wheel off you need to break the bead on the tire. I removed the valve core and put my knees into the tire and they broke loose pretty easily. Then you need 3 big metal tire levers and some dish soap. The rest is fairly straight forward. Wrestle the old tire off and on the new! If you haven't gotten new tires yet I highly recommend the Avon Viper Stryke in 130/70-12 rear & 120/70-12 front! Good luck!
