Author Topic: oil on spark plug :-s  (Read 1082 times)
sticlistul
  • Sex, Scoot and Rock 'n' Roll
« on: April 22, 2010, 01:22:46 PM »
Today I've changed the original spark plug  (at 14150km) with an NGK C7HSA and i've start the engine ,run it for about 4 min and when I've taked it out I find oil on thread the top of the spark it wasn't wet ( but it was black I think is beacouse of airfilter ,I didn't change yet and it could run rich) or it can be from the oil ? so do you have oil on spark plug ?
Re: oil on spark plug :-s
« Reply #1 on: April 22, 2010, 01:57:02 PM »
...sounds like a rich condition....
..did you just run it at idle??
..if so, you can adjust your idle screw clockwise slightly to reduce the amount of petrol in the fuel mix...
sticlistul
« Reply #2 on: April 22, 2010, 03:14:25 PM »
yes it was at idle I've cleaned the air filter with a vacum (until I change the air filter with a free flow one and a 88main jet )And with that I hope I will do 80 km/h on flat , but for next plug chop reading I will cleen the spark I have now with a wire brush ....I don't want to buy an other one
« Reply #3 on: April 22, 2010, 05:45:59 PM »
...probably gonna be more like 72-75 kmh on th flats...
sticlistul
« Reply #4 on: April 22, 2010, 05:55:27 PM »
I already have 70-72km/h on flat ( and I didn't get the new rollers yet ,this one are prety damaged ,I just hope the 5 g rollers don't cut my speed)
« Reply #5 on: April 23, 2010, 12:02:33 AM »
Even tho you have a stock paper element you can still use gasoline to clean it. A small pan will work to sort of shake it around in. It will work much better when it cleaned out. Just be sure to dry it well before using.
