..hell, it might just be a pipe dream of mine that it's different...i do run larger jets...that's a fact...
..but the principle is the same...
..do you have a welding supply shop anywhere in your area??
..you can get the torch cleaner drills or the little torch cleaning rasps there...
..my set goes down to fifteen thousandths inch...
..they're like 20 bucks...
..then you can get you a bit of solder, melt it into your jet, and drill it to whatever diameter you need...custom size your jets if you so desire....
