Author Topic: Variator  (Read 1083 times)
Gravzy
Variator
« on: April 27, 2010, 09:40:49 PM »
hey all im looking at getting a variator weekend after next and am looking at three different ones all say they will fit agility but was wundering if any of you had one fitted and noticed the difference.
MALOSSI MULTIVAR VARIATOR
Pro variator kit from CPH
Polini speed control variator kit
that the three anyone knows anything please helppp
ohhh and a very good site for anyone who needs parts
http://www.adrenalin-pedstop.co.uk/
(dont just automatically go under kymco agility section like i did many parts on baotian and similar fitt agility)
Re: Variator
« Reply #1 on: April 27, 2010, 11:32:11 PM »
That's the way it is w/ most of our scoots. There are many companies/models that share the same supplier of parts. Have you checked out SIP?  http://www.sip-scootershop.com/main/base/Home.aspx   I would get the Polinni to see how good it is in the long run IF I had a scoot to try it on. I do have the Malossi, and it has not seen the begining of it service span! I only use there rollers also w/ are twice as much as replacements but I only replace them one a year (+/-) The cph?
Shaka
Re: Variator
« Reply #2 on: April 28, 2010, 01:35:13 AM »
I've been using the Malossi for some time now with great results!  I can't comment on any of the others as I haven't personally used them, but I am curious about the Polini 9 roller set-up.
Re: Variator
« Reply #3 on: April 28, 2010, 10:36:48 AM »
..well, mine has...remember those three bosses that i f*cked up during my 3 roller excursion? (never do it)...
..they're getting worse, not much, but my ramp plate is able to move around a bit more than normal....
...lessons learned...
