Author Topic: TIME FOR A BASIC TUNE-UP/ UPGRADE  (Read 43591 times)
Re: TIME FOR A BASIC TUNE-UP
« Reply #120 on: May 24, 2010, 11:45:59 PM »
..welll...you should get rid of that airbox anyway.....
...sucks about the intake bolts...
..all i have is a clamp....
0BARK4322
« Reply #121 on: May 25, 2010, 12:21:35 AM »
ONCE YOU GOT THE CARB OFF, WAS IT AN EASY JOB TO CHANGE THE JETS AND DID YOU NEED AND SPECIAL TOOLS
« Last Edit: May 25, 2010, 08:11:16 AM by 0BARK4322 »
ALL STOCK
« Reply #122 on: May 25, 2010, 12:25:23 AM »
..the jet will be removed by either a flat-tipped screwdriver or a small wrench...like a 6" adjustable wrench....
..i've had both types of jets...slotted and hex-head....
0BARK4322
« Reply #123 on: May 25, 2010, 12:38:58 AM »
OK, I WAS GOING TO ORDER THE POWER PACK FROM MHR BUT THEY ARE OUT OF STOCK SO I GUESS I WILL JUST GET THE JETS AND VARI/CLUTCH SET
ALL STOCK
« Reply #124 on: May 25, 2010, 12:40:27 AM »
...ive been searching over-range variator kits...
...that's my next upgrade....
0BARK4322
« Reply #125 on: May 26, 2010, 08:37:37 AM »
HEY MUDFREEK HERE IS PICTURE ALSO SOME OF THESE GUYS MIGHT HAVE CHANGE THEY ZX-50 TO REAR DISK BRAKE
ALL STOCK
Shaka
« Reply #126 on: May 26, 2010, 01:37:49 PM »
That's gives a good idea of what is needed for the disk brake conversion on a ZX50.  Can you post a pic of where that swing-arm mounts to the engine?
0BARK4322
« Reply #127 on: May 26, 2010, 11:05:09 PM »
I'LL DO THAT TOMORROW, I HOPE I DON'T HAVE TO REMOVE ANYTHING  :-X
« Last Edit: May 26, 2010, 11:08:34 PM by 0BARK4322 »
ALL STOCK
« Reply #128 on: May 27, 2010, 12:05:36 AM »
Just knock it off w/ a hamm'a
« Reply #129 on: May 27, 2010, 12:15:32 AM »
...we neandertals use big rocks....
..then eat buffalo...
0BARK4322
« Reply #130 on: May 27, 2010, 01:14:29 AM »
IT SEEMS TO BE BEHINED THE MUFFLER--HARD TO GET GOOD SHOT
ALL STOCK
Shaka
« Reply #131 on: May 27, 2010, 04:49:27 AM »
Thanks anyways for looking!  Not really that big of a deal, just curious.  I've seen that blow-apart diagram, it looks like it bolts up to the engine where the exhaust bolts on, at least on mine.
0BARK4322
« Reply #132 on: May 27, 2010, 08:38:22 AM »
YEA BUT MUDFREEK WANTED TO SEE A PICTURE OF THAT SET-UP, I WILL TRY TO PUT UP SOME PIC ON THURDAY IF I CAN GET A GOOD OF THE SHOT-----IT LOOKS LIKE IT BOLTS ON LIKE THE ZX-50
« Last Edit: May 28, 2010, 08:29:56 AM by 0BARK4322 »
ALL STOCK
Shaka
« Reply #133 on: May 30, 2010, 04:24:27 AM »
That might work!  I'm sure it would still take quite a bit of work though!
0BARK4322
« Reply #134 on: May 30, 2010, 01:50:34 PM »
YEA----HE MIGHT BE BETTER OFF JUST BUYING ONE THAT COMES WITH BOTH F/R  DISK BRAKES AND I DON'T THINK THEY MAKE THE SWINGARM INTERCHANGEABLE
« Last Edit: May 31, 2010, 01:42:30 PM by 0BARK4322 »
ALL STOCK
