Author Topic: TIME FOR A BASIC TUNE-UP/ UPGRADE  (Read 43399 times)
Re: TIME FOR A BASIC TUNE-UP
« Reply #15 on: May 03, 2010, 01:48:33 AM »
Wear a helmet on the first ride! lol...
Hoolander2
« Reply #16 on: May 03, 2010, 02:27:09 AM »
From Dr. Pulley, "HiT Clutch" user manual:
2.
Powerful takeoff but
no riding comfort.
Engaged rev too high. Replace with softer clutch spring.
Actuation timing too early. Replace with harder pillow spring.
3.
Powerful takeoff but having
vibration at initial stage
Engaged rev too low. Replace with harder clutch spring.
Belt slippage** happened in the
front driving pulley. Replace with heavier roller.
Belt slippage happened in the rear
driven pulley. 4. Replace with harder torque spring.
Smooth takeoff but solid
engagement not obvious
pulley. Replace with a new belt.
* It’s dangerous to actuate the throttle fully and suddenly when softer pillow spring and harder clutch spring are used at
the same time, as the vehicle might jump into the air abruptly to cause serious damage or injury.
** The belt slippage can happen in the pulley due to the solid engagement and less slippage with the clutch bell. The
abnormal surface temperature of pulley can be taken as checkpoint to see whether the belt slippage exists.
So apparently it IS possible to wheelie one.  :D
« Last Edit: May 03, 2010, 02:30:36 AM by Hoolander2 »
Shaka
« Reply #17 on: May 03, 2010, 04:00:14 AM »
I can vouch for that!  ;D
« Reply #18 on: May 03, 2010, 04:05:51 AM »
Over the past few weeks I have been loosing top end, and take off power. I started to foul plugs in 2-3 days. I figured it must be a loose jet so I pulled the carb/cleaned it w/ no obvious problem. On a hunch I pulled the freshly cleaned air filter, and A LA WA... In the air, almost on my a$$. I forgot how much it has on the bottom.
0BARK4322
« Reply #19 on: May 03, 2010, 08:26:48 AM »
WHHHHHAT IS HOOLANDER TALKING ABOUT  :'(
ALL STOCK
« Reply #20 on: May 03, 2010, 11:35:23 AM »
I'm pretty sure it is a section for tuning the cvt taken from a Dr. Pulley install guide.
Hoolander2
« Reply #21 on: May 03, 2010, 04:19:08 PM »
Yep, that's what it is.  I just thought it was funny how they worded the part about jumping into the air!!!   ;D  You know, since you had wondered about wheelies.  Ha!
I emailed Dr. Pulley (actually it's called Unionmaterial.com)  a couple weeks ago inquiring about sliders and they sent me a lot of stuff about their sliders and clutches. Apparently you can still get sliders directly from them.  They offered me a deal for a HiT clutch for about $400.  They'd throw in a set of sliders for free.
« Reply #22 on: May 03, 2010, 05:53:33 PM »
That's not too bad of a deal! The Malossi Delta for your scoot is around 390. alone. If they throw in 40 bucks worth of sliders all the better.
Shaka
« Reply #23 on: May 03, 2010, 10:46:49 PM »
I've heard great things about the Dr. Pulley clutches as well!
0BARK4322
« Reply #24 on: May 03, 2010, 11:42:20 PM »
I SEE A LOT CAN BE DONE WITH THESE SCOOTER BUT AROUND 50 MPH IS GREAT FOR JUST A BOSS DRIVE CHANGE AND TO BE TRUTHFUL IT CAN REACH THAT WITHOUT A CDI DERESTRICTION
ALL STOCK
« Reply #25 on: May 03, 2010, 11:44:44 PM »
Only w/ the S9 tho! If you did the rest of the mods/kit...70mph. Not too shabby for a $1'300 toy
« Reply #26 on: May 03, 2010, 11:45:25 PM »
...i want me a s9....
..i just wanna go fast.....
0BARK4322
« Reply #27 on: May 04, 2010, 12:10:23 AM »
70 MPH 'WOW' CAN THOSE BRAKES STOP THAT SPEED AND WHAT ABOUT THE FRAME
ALL STOCK
« Reply #28 on: May 04, 2010, 12:11:03 AM »
..they'll stop eventually................................................
« Reply #29 on: May 04, 2010, 12:15:47 AM »
Dual discs, and the frame is chromoly. The scoot was made for circuit racing. That may be why they stopped producing them. Price vs. cost
