Did you miss your
activation email
TIME FOR A BASIC TUNE-UP/ UPGRADE
Pages:
10
11
12
13
20
Topic: TIME FOR A BASIC TUNE-UP/ UPGRADE (Read 43542 times)
SUPER 9 MANN
Full Member
Re: TIME FOR A BASIC TUNE-UP/ UPGRADE
Reply #150 on:
June 12, 2010, 08:55:25 PM »
I have taken my cover off, which bolt do i remove.
0BARK4322
Reply #151 on:
June 12, 2010, 08:59:26 PM »
NOW REMOVE THE BOLT THAT HAVE THE ROUND DISK WITH TEETH ON IT---TO THE LEFT----IF YOU HAVE AN IMPACT WENCH IT WOULD HELP BETTER
ALL STOCK
SUPER 9 MANN
Full Member
Reply #152 on:
June 12, 2010, 09:05:33 PM »
Ok it came off with no problem.
0BARK4322
Reply #153 on:
June 12, 2010, 09:16:18 PM »
JUST PULL THAT DISK OFF AND YOU WILL SEE THIS IN PICTURE--JUST PULL THAT BELT(FRONT ONLY) OFF AND MOVE IT OUT THE WAY
ALL STOCK
SUPER 9 MANN
Full Member
Reply #154 on:
June 12, 2010, 09:18:36 PM »
Ok got it, just the front of the belt is out the way.
0BARK4322
Reply #155 on:
June 12, 2010, 09:23:18 PM »
NOW THE SAME PLACE WHERE YOU REMOVE THE BELT IS A CYLINDER THAT SLIDE OUT THE CAP MAY MOVE WITH IT BUT JUST HOLD IT AND TAKE OFF THAT CYLINDER WHICH IS THE BOSS DRIVE
ALL STOCK
SUPER 9 MANN
Full Member
Reply #156 on:
June 12, 2010, 09:28:16 PM »
I have taken the boss out and it seem to have a different diameter at one end then the new one.
0BARK4322
Reply #157 on:
June 12, 2010, 09:33:19 PM »
YES IT DOES --THAT WHY YOUR SPEED WAS AT 30 MPH ONLY---IT WAS RESTRICTED WITH THAT SLEEVE---THE ONE ON RIGHT IS THE ONE THAT YOU SHOULD HAVE
ALL STOCK
SUPER 9 MANN
Full Member
Reply #158 on:
June 12, 2010, 09:35:50 PM »
I have that one, now i am going to install it in the reverse i assume.
0BARK4322
Reply #159 on:
June 12, 2010, 09:42:09 PM »
OK--JUST MAKE SURE THAT YOU PUT THAT NUT BACK TIGHT AND TAKE YOUR TIME AND IF YOU HAVE ANY TEMPORARY LOK-TIGHT WOULD BE GOOD---AND !! WOW !! YOU CAN UPGRADE YOUR SCOOTER AND STAY IN TOUCH WITH YOUR COMPUTOR--GRRREAT--LET MY KNOW WHEN YOUR FINISH
ALL STOCK
SUPER 9 MANN
Full Member
Reply #160 on:
June 12, 2010, 09:44:47 PM »
Ok, lets see what happen.
undead primate
Reply #161 on:
June 12, 2010, 10:31:09 PM »
...make sure the variator stays in place!!!!
..and the rollers don't get discombobulated!!!!!
sidthesloth
Kymco ZX50
Reply #162 on:
June 12, 2010, 10:47:49 PM »
undead primate
Reply #163 on:
June 12, 2010, 10:50:51 PM »
...yeah f*ckin outta whack!!!
sidthesloth
Kymco ZX50
Reply #164 on:
June 12, 2010, 10:56:01 PM »
AAAHHH!!!
Back
