Author Topic: TIME FOR A BASIC TUNE-UP/ UPGRADE  (Read 43467 times)
art
Re: TIME FOR A BASIC TUNE-UP/ UPGRADE
« Reply #225 on: June 15, 2010, 12:52:54 AM »
Hey just a thought here about 2t oil,I ran blendsall in my dirt bikes years ago It performed great,but when it came time to teardown left kind of a sticky residue an everything,I was a honda guy and ran yamalube in everything from then on burns quit a bit cleaner.No yamaha shop close so running motul full synthetic now. Don't know how good it is yet.
« Reply #226 on: June 15, 2010, 12:54:01 AM »
...a lot...i'll have to look it op...but they are wearing at half the rate oh the chengs or the kendas i've run...
0BARK4322
« Reply #227 on: June 15, 2010, 12:56:43 AM »
OK GREAT-------HAVE YOU EVERY RUN A SYNTHETIC OIL IN YOUR SCOOT
ALL STOCK
art
« Reply #228 on: June 15, 2010, 01:04:19 AM »
The gal i bought my my 2005 from ran bellray si 7 for 10,000 miles when i opened the cylinder up I can still see the factery hone marks going to run it as is,it does tend to clog a bit at the pipe,thats why im going to try the motul'bellray tended to do this with my dirt bikes too.So far i think yamalube is at the top.I'm sure there are other opinions out there  ;D
« Reply #229 on: June 15, 2010, 01:12:03 AM »
...been using Royal Purple 10w 40 for quite a while....
0BARK4322
« Reply #230 on: June 15, 2010, 01:15:03 AM »
WHY USE SYN OIL WHEN IT JUST BURN RIGHT OUT
« Last Edit: June 15, 2010, 08:25:29 AM by 0BARK4322 »
ALL STOCK
« Reply #231 on: June 15, 2010, 01:15:38 AM »
« Reply #232 on: June 15, 2010, 01:18:57 AM »
...full synthetics generally contain certain elements that "cling" to you mechanical parts better than BP distillates....
..induce less wear on your bits...
 ;D
0BARK4322
« Reply #233 on: June 15, 2010, 01:22:53 AM »
REG OIL FILL-UP CHANGES WILL DO THE SAME---I NEVER USE SYN OIL AND NEVER HAD A PROBLEM ON SCOOT OR AUTO---I GUESS ITS A MIND THING
ALL STOCK
art
« Reply #234 on: June 15, 2010, 01:23:51 AM »
Thats the hype less friction less heat longer lasting motor.I'll have to dig out the crank of the vespa I'm working on to show what just any old oil can do It's was so frozen I broke the cylinder getting it out.
« Reply #235 on: June 15, 2010, 01:25:21 AM »
..it could be....a mind thingy, i reckon...
..all i know is that these lil engines work really hard...
..if i can give 'm a one-up with a bit of friction reduction, then it's worthwhile to do so...
« Reply #236 on: June 15, 2010, 04:36:11 AM »
I use ONLY synthetics in EVERY engine I own. IT WORKS BETTER! The only failure I have had is due to using "stock brand" 2t oil, and I burned a hole in my piston dome. I use Golden Spectro 2t. These oils leave less carbon, and allow the engine to run cooler (few degrees) so they do make a difference. ANYONE that says otherwise is just WRONG!
0BARK4322
« Reply #237 on: June 15, 2010, 08:24:06 AM »
WELL I GUESS THEY BOTH WORK BECAUSE I HAVE SEEN CARS GO FOR TEN YEARS(FATHER) I NEVER USE SYN OIL AND NO PROBLEM AND OF COURSE THERE PROBABLY WAS A TIME WHEN THERE WAS NO SYN OIL ANYWAY----BUT I GUEST IT BETTER BUT NOT MANDATORY
ALL STOCK
« Reply #238 on: June 16, 2010, 12:42:28 AM »
I won't ride w/out it. Sorta mandatory for me.
0BARK4322
« Reply #239 on: June 16, 2010, 12:45:01 AM »
GO WITH WHAT WORKS FOR YOU
ALL STOCK
