..yes, from the positive batt termnal..thru an inline fuse (Advance Auto also)..then through a switch so you can turn them on or off (Advance Auto)...to the Positive led's leads...from their negative leads, connect a wire to the batts negative terminal..
..LED lighting takes very small amounts of current...
..depending on how many you use, a 1/5 - 1 amp fuse will be enough...
..it's easy, and you don't have to worry about screwing up any of your scoots other wiring...
..you can also light them when the scoot isn't running...
