Did you miss your
activation email
TIME FOR A BASIC TUNE-UP/ UPGRADE
Pages:
3
4
5
6
20
Topic: TIME FOR A BASIC TUNE-UP/ UPGRADE (Read 36417 times)
0BARK4322
Re: TIME FOR A BASIC TUNE-UP
Reply #45 on:
May 06, 2010, 08:03:08 AM »
HEY. I SEE YOUR WHOLE AIR FILTER IS MISSING AND YOU HAVE THAT LITTLE FILTER IN PLACE-----DOESN'T IT GET DIRTY FAST AND HOW OFTEN DO YOU CHANGE IT. IT DOES LOOK BETTER THEN MY BULKY AIR BOX
ALL STOCK
undead primate
Reply #46 on:
May 06, 2010, 10:48:12 AM »
..that's a K&N brand high flow air filter...gives your scoot a little more oomph, and makes it louder also...
..the stock A50 airbox was butt-ugly...lol..
..it fairly forgiving as far as needing to be cleaned...
..just pop it off, blow it out with compressed air...good to go!!
..i clean mine about once a month whether it needs it or not...
0BARK4322
Reply #47 on:
May 06, 2010, 11:20:59 PM »
CAN THAT BE PUT ON A STOCK SET-UP (NO JET OR BIG CARB KIT)
ALL STOCK
Shaka
Reply #48 on:
May 07, 2010, 02:03:56 AM »
You can put one on a stock carb, but you will have to re-jet.
undead primate
Reply #49 on:
May 07, 2010, 02:07:54 AM »
..yeah, what shaka said...
..it's a performance enhancment, but you must up-size yor carb's main jet and also adjust your idle mix, via the idle mix adjusting screw on your carburetor.......
You never know do ya!
Close enough to get the idea!
Reply #50 on:
May 07, 2010, 06:36:08 AM »
Go for it! It is just a scoot. The hotter the spark you can get the more fuel you can burn. The more fuel= the more air you need. Get a good coil, and then get an air filter/jets. The coil should not cost more than $20.00 delivered. CAN THAT BE PUT ON A STOCK SET-UP (NO JET OR BIG CARB KIT) NO!
0BARK4322
Reply #51 on:
May 07, 2010, 08:09:30 AM »
THAT SOUNDS GREAT BUT MAN I TRYING TO STAY AWAY FROM THE CARBS, I DON'T WANT IT TO START ACTING UP LIKE I HERE SOME GUY DO, I WAS WONDERING IF THE AIR SCREW IS THE SAME AS THE IDLE ADJUSTMENT
ALL STOCK
Reply #52 on:
May 07, 2010, 06:46:36 PM »
The idle mixture adjusting screw is some times called an air screw. You turn it either way in 1/4 turn increments. You want to get the best/highest rpm's on the adjustment. Once you get it to its peak, turn it 1/4 turn counter clockwise. that will be the final setting. you can then use the idle speed screw to get the idle rpm's where you need them. Always have a clean air filter before adjusting the mix.
0BARK4322
Reply #53 on:
May 07, 2010, 11:39:55 PM »
NO I'M LOOKING TO INCREASE MY IDLE TO 1800-2000 RPM AND ALSO WHY PEAK IT THEN TURN IT 1/4 WAY COUNTER CLOCKWISE
ALL STOCK
Shaka
Reply #54 on:
May 08, 2010, 12:06:46 AM »
You turn it back to be on the safe side. That 1/4 turn makes it slightly richer. At peak rpm with the mix screw you are actually a little lean.
0BARK4322
Reply #55 on:
May 08, 2010, 01:26:26 AM »
OK, GREAT----I WILL ORDER THE VARAITOR KIT,BELT,KN FILTER,SPARK AND SHOULD I CHANGE JUST THE MAIN JET TO 95, I THINK I HAVE A 92 STOCK.
ALL STOCK
Reply #56 on:
May 08, 2010, 03:17:22 AM »
You might wan to get a KIT of jets. Say 95-106. There is no real way to predict what you may need. $20.00 on jets is not too bad, and it is always better to be safe than LEAN.
0BARK4322
Reply #57 on:
May 08, 2010, 08:57:51 AM »
OK, A SET OF MAIN JETS RIGHT---DO THAT COME IN A PACK OF 95-106
ALL STOCK
undead primate
Reply #58 on:
May 08, 2010, 12:16:09 PM »
...i saw a super9 just like yours today obark....where you live??
Reply #59 on:
May 08, 2010, 01:07:02 PM »
DO THAT COME IN A PACK OF 95-106 You can ask for the jets in that range 95/98/100/102/104/106
Back
