Author Topic: TIME FOR A BASIC TUNE-UP/ UPGRADE  (Read 38276 times)
Hoolander2
Re: TIME FOR A BASIC TUNE-UP
« Reply #60 on: May 08, 2010, 05:15:17 PM »
OBARK, you asked if the air screw is the same as the idle adjustment.  NO.  These guys are referring to the Idle air mixture screw, not the Idle speed screw.  They are 2 different screws.
« Last Edit: May 08, 2010, 05:17:11 PM by Hoolander2 »
0BARK4322
« Reply #61 on: May 08, 2010, 10:31:58 PM »
I HAVE NOT DONE IT AS YET BUT THE IDLE ADJUSTMENT SCREW IS THAT CABLE THAT ROTATE A LEVEL ON THE CARB WHEN YOU TURN THE THROTTLE(THERE IS A SCREW OVER THERE---RIGHT)
ALL STOCK
0BARK4322
« Reply #62 on: May 08, 2010, 10:36:05 PM »
...i saw a super9 just like yours today obark....where you live??
UNLESS YOU SAW ME IN UPSTATE NY (UTICA) FOR THE WEEKEND YOU ARE SEEING MY TWIN SCOOTER.LOL
« Last Edit: May 09, 2010, 06:45:56 PM by 0BARK4322 »
ALL STOCK
« Reply #63 on: May 08, 2010, 10:42:43 PM »
..yeah, it was it's twin....
..i thot.."obark?"
..my dad's up that way since last friday..
..camping on th' moose river...he sent me pics on my cell...
..beautiful country...
Hoolander2
« Reply #64 on: May 08, 2010, 10:54:12 PM »
  Right.  ;)
0BARK4322
« Reply #65 on: May 08, 2010, 11:24:11 PM »
You can put one on a stock carb, but you will have to re-jet.
I WENT TO STADIUM YAMAHA SITE AND THEY SEEM TO HAVE NO AFTERMARKET PARTS FOR MY 2003 SUPER 9--WHO ELSE MIGHT HAVE
ALL STOCK
Shaka
« Reply #66 on: May 08, 2010, 11:47:41 PM »
OBARK, the idle speed screw is not the "barrel adjuster" up on the throttle.  I think you may be referring to that.  That is to take the free play out of the throttle.  The idle speed screw is usually the larger center screw on the carb.  It sticks into the carb right in the middle where the slide is.  It actually sets how far the slide can close or move down.  The idle mixture screw will be smaller and on the downstream side of the idle speed screw.  A good starting point for both screws is typically 1.5-2 turns out.  First set the idle speed, then fine tune for max rpm with the mix screw.  Then turn the mix screw 1/8 turn back out to richen it a tad more.  You may then have to re-adjust the idle speed screw to lower the rpm's back down to where the wheel doesn't turn on the center stand.  Once the carb is set you can check the throttle grip for free play and adjust it with the barrel adjusted on the handle bar.  The service manual will state the free play.  It's usually about 2mm.
0BARK4322
« Reply #67 on: May 09, 2010, 12:40:43 AM »
DO YOU THINK I CAN ADD  A K&N FILTER AND(SET THE IDLE MIXTURE SCREW TO A RICHER SETTING (FOR MORE FUEL)AND NOT HAVE TO CHANGE THE MAIN JET--HAVE YOU TRIED IT BEFORE
ALL STOCK
Shaka
« Reply #68 on: May 09, 2010, 12:44:46 AM »
The air screw only effects the idle circuit, so no.  You will have to change your main jet if you put on a K&N.
« Reply #69 on: May 09, 2010, 03:02:33 AM »
http://www.jiangwayne.com/scooter/index.php   This site has the BEST parts you can buy, It is a good site to drool over.
0BARK4322
« Reply #70 on: May 09, 2010, 05:06:24 PM »
THAT'S IN CANADA---AW MAN--CAN THESE WHEELS MAKE IT
« Last Edit: May 09, 2010, 06:39:53 PM by 0BARK4322 »
ALL STOCK
« Reply #71 on: May 10, 2010, 02:03:13 AM »
Just a 2-3 day trip for you!. I order from Taiwan, and get parts in 2 weeks. They can send you stuff from Canada by Pigeon in a few days.
0BARK4322
« Reply #72 on: May 10, 2010, 08:32:31 AM »
I RATHER HAVE A STORK, HE CAN HOLD MORE----VARIATOR,SPRING,JETS,EXHAUST ETC.
ALL STOCK
ispud
« Reply #73 on: May 10, 2010, 12:52:41 PM »
writing in all caps is errrr..........errrrrr.........worth some research??
« Reply #74 on: May 10, 2010, 06:56:17 PM »
All Caps. is cruise control for COOL!
