Author Topic: x500 weight limits  (Read 3728 times)
griffon_j9
x500 weight limits
« on: May 01, 2010, 08:35:36 PM »
Hi all,
was just thinking about either getting a xciting or silverwing.... and was wondering what the weight limit fort he xciting was?  I read somewhere that it was only 330..... can't ride two up with that low of a number
thanks
2010 Red Xciting 500RI  51 MPG so far
Re: x500 weight limits
« Reply #1 on: May 01, 2010, 09:48:50 PM »
Just a quick browse, and I didn't see the specs. but I think 2up on any 500cc is not a lot of fun. Highway cruising 2up needs a bigger bike. Around the back roads ...OK
rick71
« Reply #2 on: May 02, 2010, 01:40:58 AM »
My first bike was a 82-83(?)  Kawasaki 440 LTD. I only took one long-ish trip on it 2 up. Started in Inverness, Fl, up through Ocala, Silver Springs, over to I-95 and down to Cocoa to watch a shuttle launch. Not a problem :-)
Rick
jan.strydom
« Reply #3 on: May 02, 2010, 01:21:41 PM »
Hi all,
thanks
I am 150kg and my wife is 50kg and our 500i runs like a baby - we even fill the box with stuff - i believe it's perfect!!!
rick71
« Reply #4 on: May 02, 2010, 01:31:50 PM »
Jan,
Am I understanding you correctly? You are putting a 200 kg (440 lb) load, plus cargo on the X500?
How is the mileage, and do you have the suspension high?
I'm asking because I'm 118kg, and I'd like to throw someone on the back every now and then.
Can anyone else chime in with what loads you are putting on the X500?
Rick
jrd4849
« Reply #5 on: May 02, 2010, 03:16:49 PM »
The manual for mine states the max weight capacity at 150 kg (330 lbs). That being said my wife and I are right at that limit and the scoot has no problem going down the road with us on board.
Jim. 2009 Xciting500Ri
Hoolander2
« Reply #6 on: May 02, 2010, 04:23:27 PM »
I'm 6' and 134 pounds.  With me on, the Xciting handles and accelerates well.  With my 200 pound friend on the back, (which puts it right at 334 pounds) we still get there but acceleration is nowhere near as good.  I wouldn't want to be on an interstate or expressway with both of us for any long trip.  I know the Xcitng is promoted, at least partially, as a touring scooter but, in my opinion, it is near the lower limit of power for riding on interstates and such, even one-up. Maybe I'd feel the same about the Silver Wing too.
For me to feel really comfortable on interstates and expressways, I'd want a whole lot more power. And yes, I used to ride a good bit on those kinds of highways.  I only really felt confident when I moved to a 750cc.
I've never been the kind to want to really load up a bike with lots of weight.  But I don't tour and have no desire to.  Everything is relative to what you're used to and what you want to do.  In my opinion, for touring or frequent two-up riding, look for the highest horsepower you can get for the money you've got.
« Last Edit: May 02, 2010, 04:32:40 PM by Hoolander2 »
griffon_j9
« Reply #7 on: May 02, 2010, 11:56:54 PM »
Thanks for the info everyone! wow 440, I guess I should not worry then.
Currently I am 220 and driving a grandvista 250 on the highway and doing ok (just ok and not much more then that) Though it does kinda suck when driving to work in rush hour X_x;;  that is one reason I am looking to upgrade.
I will continue to read as more post show up, am curious to see what everyone says
later
jan.strydom
« Reply #8 on: May 03, 2010, 07:31:31 AM »
Jan,
I tour at 60/70 and I believe I get around 50mpg - i set the suspension at no 2 - I have no problem with touring comfortably and the 500i has good reserve power.
Hoolander2
« Reply #9 on: May 03, 2010, 04:57:25 PM »
To be completely honest, my valves may not be adjusted properly at this point so I may be suffering a lack of power from that.  Also, I have the carburated version (2007).  Injected models may have more power.
As far as the load carrying capacity, it was fine with two up 330 lbs.  In other words, it wasn't bottoming out.  Ride was fine.
griffon_j9
« Reply #10 on: May 03, 2010, 11:48:37 PM »
I wonder if it has to do with a center of balance (gravity) thing?
« Reply #11 on: May 03, 2010, 11:49:42 PM »
..dude...did i miss something..
..what happened with your valves??
Hoolander2
« Reply #12 on: May 04, 2010, 01:49:06 AM »
Nothing really "happened", though I think they're just out of adjustment.  Hearing ticking/ringing which I think is the valves.
I attempted to adjust but found my thinnest feeler gauge to be not thin enough.  Book calls for .1mm and the thinnest I had was .16 or somthing.  So that's what they're adjusted to right now. Don't know if that's enough to cause loss of power or what I'm hearing but maybe so. Zombie thinks so and I trust him.
I did get thinner gauges so next time will get it down where it should be hopefully.
« Reply #13 on: May 04, 2010, 01:53:41 AM »
..i think zombie's probably right too...that's 60% more than spec....
« Reply #14 on: May 04, 2010, 02:12:45 AM »
I sure hope you are using hi test fuel!
