Author Topic: x500 weight limits  (Read 3726 times)
Hoolander2
Re: x500 weight limits
« Reply #15 on: May 04, 2010, 02:22:06 AM »
Yes I am.  Have since I got it.  Tell me what that does for me Z?
« Reply #16 on: May 04, 2010, 02:25:55 AM »
...i don't think my A50 would pull my big ass up a hill a +60%...
..really....
« Reply #17 on: May 04, 2010, 02:27:42 AM »
If your valves are not fully opening there is a chance of running a lean mix. That will amplify w/ rpm's, and build heat exponentially. The heat will pre ignite the lean mix, and give you detonation. The higher octane/flash point of hi test fuel can control this (to a certain extent) Don't loose any sleep over it, but the valve adjustment is one of the most important things to do correctly. The correct breathing/temp. of your cylinder depends on it.
