Author Topic: Help!  (Read 2701 times)
scootdog
Help!
« on: May 28, 2008, 07:36:18 PM »
I changed the oil, changed the tranny oil, cleaned the pan gasket....can't seem to find the oil filter.....maybe only on the 500? (Kymco Xciting) and can't find the air filter, and can't locate the spark plug...doesn't show where it is in the handbook. Does anyone know where these things are located on the 250?? Pleaseeeeeeeeee help..... Thank you very much...Larry
tony_dt
Re: Help!
« Reply #1 on: May 29, 2008, 03:22:04 AM »
I don't think that it has a filter. Only a screen. Air filter and sparkplug are accessed on the left-hand side of the scooter. The airfilter sits under the rear sidepanel if I remember correctly. You shouldn't have to remove any bodywork to access.
scootdog
Re: Help!
« Reply #2 on: May 29, 2008, 06:15:08 AM »
Thanks a lot, Tony...I will check it out and let you know how it went.....appreciate the info......Larry
olbull
Re: Help!
« Reply #3 on: May 29, 2008, 12:44:46 PM »
There isnt  a  filter..The  screen is   is  in  the center  of  the  oil pan..Drain  plug is on  side stand  side  of  oil pan.. Perhaps  reading the  owners  manuel  would  answer  your  questions...
2007 P250
If  your  not the lead dog the  scenery never  changes
obxbiker
  • ADMIN/SITE BUILDER @ www.piwyr.co.cc
Re: Help!
« Reply #4 on: May 30, 2008, 03:27:56 AM »
He said he could not see it there... (??)
Quote
Venox info @ www.piwyr.co.cc
2003 (3) Super9 LC's heavly modified........
2004 Modified Venox ''OBnoXious Nox'' ......
2006 ''Yellow NOX''.......
scootdog
Re: Help!
« Reply #5 on: June 01, 2008, 06:58:09 AM »
Tony, thanks for your info. I was able to find the air cleaner right away, and the spark plug also. Once you have an idea where to look, you find fast! Thanks again for your help.....Scootdog
tony_dt
Re: Help!
« Reply #6 on: June 01, 2008, 05:05:47 PM »
No problem Scootdawg! At first appearance it looks like it is going to be hard to access but it really isn't too bad.
kawzak
Re: Help!
« Reply #7 on: July 04, 2008, 03:09:41 AM »
Else where in this forum under general discussion ,page 2 -I seen a web site you can download a PDF file for a parts manual (130+pages) and a repair/maintenance manual (200+ pages) for free. Just be sure to have lots of time on your hands and new printer ink cartridges-and lots of paper, it takes quite some time. If you still have questions repy to this post and I will look it up. Hope this helps.
michiman
Re: Help!
« Reply #8 on: July 06, 2008, 04:16:48 AM »
I saved them to my hard drive...  Then I only print the pages I need...
Hmm...  Great Idea....
Save a tree...
 ;D ;D ;D ;D
