Author Topic: something strange with gears  (Read 4045 times)
sticlistul
  • Sex, Scoot and Rock 'n' Roll
« on: May 04, 2010, 02:53:25 PM »
In manual it says that the ratio is 1:11.05 ,that means when rear wheel spins one time the clutch bell should spin 11.05 times ... but at mine I have to spin the bell 13.6or7 for a complete wheel spin ....  so that means I have an other gear ratio ? That should explain why most of chinese 4t scoot are faster than mine :(
« Last Edit: May 04, 2010, 02:56:21 PM by sticlistul »
Re: something strange with gears
« Reply #1 on: May 04, 2010, 11:49:15 PM »
..i believe mine is 13.*...
..i kinda remember counting once....sssso......
..and i've not come across a faster chinese 4t yet....
 ;D
Dark13
« Reply #2 on: May 05, 2010, 12:47:20 AM »
just counted and mine it a little over 11
proud owner of a 2009 kymco agility 50
« Reply #3 on: May 05, 2010, 12:49:45 AM »
..dang...i might be wrong...gonna check tomorrow..
..just ain't got it in me to open that can of worms tonite...lol...
« Reply #4 on: May 05, 2010, 01:41:59 AM »
...just couldn't stand it.....i hadda check...
..13.6 revolutions of the clutch to one revolution of the rear tire...
 ;D
« Reply #5 on: May 05, 2010, 01:48:51 AM »
..now, i wanna know... how i can get your gear ratio....
..cause that would be frickin' awesome!!!!
Shaka
« Reply #6 on: May 05, 2010, 02:24:02 AM »
Not certain but I think Enviromoto has a Naraku gear kit that will fit the Agility.  Most of the replacements are a pretty low ratio comparatively though.  You might need to "put a kit on dat bitch" first! ;)
« Reply #7 on: May 05, 2010, 02:25:44 AM »
..how come dark13 has 11 to 1......
..Dark, did you buy your scoot new?
..have you been in the gearbox??
Shaka
« Reply #8 on: May 05, 2010, 02:29:39 AM »
When I was researching the one's on the ZX50 before I did mine I found very little and conflicting info!  It seems there really is no standard ratio for these scoots.  I think they may have done different ratios for different markets and model years.
« Reply #9 on: May 05, 2010, 02:32:17 AM »
...theory is, if I knew what d13s gearbox had in it, i could find that gearset, and put it in mine...
..muaah-haa-haaaa....
Shaka
« Reply #10 on: May 05, 2010, 02:42:06 AM »
Very true!  I found a website that lists the actual number of teeth on each cog.  It was hard to find I'll see If I can remember where it was.
« Reply #11 on: May 05, 2010, 02:44:35 AM »
...that gearset with an over-range variator, and the 20mm carb...
...that's where i need to be...
 ;D
« Reply #12 on: May 05, 2010, 02:58:26 AM »
dude, that'd be awesome....
Shaka
« Reply #13 on: May 05, 2010, 03:00:57 AM »
Not a whole lotta luck in my quick search other that I think the intermediate shaft is a 53/14.  I can't find the # of teeth on the input and output shafts.  Will keep looking.
« Reply #14 on: May 05, 2010, 03:01:46 AM »
                                        1700
 :P
