Author Topic: something strange with gears  (Read 4044 times)
Re: something strange with gears
« Reply #15 on: May 05, 2010, 03:03:06 AM »
Not a whole lotta luck in my quick search other that I think the intermediate shaft is a 53/14.  I can't find the # of teeth on the input and output shafts.  Will keep looking.
..53/14...for the A50??
Shaka
« Reply #16 on: May 05, 2010, 03:05:41 AM »
That's what I found for the intermediate shaft.  Just searched the Kymco part #.
Shaka
« Reply #17 on: May 05, 2010, 03:20:20 AM »
I'm not coming up with anything. I did find the gearing for the A50 Basic, whatever that is.  It has a final reduction of 6.65:1!!!!
« Reply #18 on: May 05, 2010, 03:23:07 AM »
...another thought...
..i'm gettin pretty frikin good speeds...
..is the spec of 11:1  or 16.6:1 actually the ratio of the clutch revolutions to the rear tire revolutions....
..it is isn't it?
« Reply #19 on: May 05, 2010, 03:25:29 AM »
..you made exclamations...
..is that a good thing??..the 6.65:1?
Shaka
« Reply #20 on: May 05, 2010, 03:28:58 AM »
That's just a super low ratio.  Either the tooth counts where mis-printed or there is something completely different with that model.  I would doubt you would even be able to get moving with that gear!  The primary reduction was 16/52 and secondary 15/51.
« Reply #21 on: May 05, 2010, 03:30:35 AM »
...wonder if that's a 2t...
Shaka
« Reply #22 on: May 05, 2010, 03:52:35 AM »
I didn't look all that closely, but it could be.  Even still that's a super low ratio.  I'm only running an 8.6:1 ratio.
« Reply #23 on: May 05, 2010, 03:53:42 AM »
...probably a mis-print....
Dark13
« Reply #24 on: May 05, 2010, 11:59:53 AM »
yea i bought mine new i am pretty sure i only got 11 turns of the bell to one full turn of the tire
proud owner of a 2009 kymco agility 50
« Reply #25 on: May 05, 2010, 07:36:26 PM »
That is exactly where the reduction ratio is measured, at the clutch... Not the engine.
sticlistul
  • Sex, Scoot and Rock 'n' Roll
« Reply #26 on: May 05, 2010, 07:59:09 PM »
thanks guys ,that means I'm not crazy ... my ratio is 13.6:1
slinger I traveled with a bunch of chinese 4t scoot and I was the slowest it's verry frustrating beacouse my scoot KYMCO has a reputation to prove\protect  :( (I'm prod that I have a kymco )but guess what.... chinese gears are suposed to fit in my scoot so I think I will give them a try .I found a set of chinese gears (primary and secondary) with 21$  when I find money I definetly gona put them in .
So I think thats the reason why agility are using lighter rollers then other chinese who use around 7 or 8gr rollers ,with stock engine.
I've read on a forum a seller tryed to test an 8:1 ratio with a 80cc kit and it was a total failure ,the scoot didn't go anywere
I've heard about agility 125 that they have ratio 6:1  :o ask someone from the other section to see if it's true .
« Last Edit: May 05, 2010, 08:03:55 PM by sticlistul »
« Reply #27 on: May 05, 2010, 09:31:42 PM »
..stic, you can get 80kmh without a gear change....
..fill me in again on what mods you've done...
« Reply #28 on: May 06, 2010, 01:56:47 AM »
...STILL.....
...dammit.....
... Dark13 has 11:1.......
Dark13
« Reply #29 on: May 06, 2010, 02:08:41 AM »
i think kymco just has really bad quality control
