Author Topic: brakes  (Read 787 times)
brakes
« on: May 06, 2010, 12:22:40 PM »
Im hearing a very small noise from my scoot sounds like wear taps on brakes could that be.
do agilty 50s have wear taps on there brakes. its only ounce in a while.sometimes when scoot is off
and im moveing it I can hear the noise. something when the tires are moveing. or could it be it needs gear oil.
Re: brakes
« Reply #1 on: May 06, 2010, 01:10:51 PM »
...well, the gear oil is pretty easy to check, and i don't know about wear tabs...
...front or rear?
Re: brakes
« Reply #2 on: May 06, 2010, 05:54:13 PM »
Hey Blue. These are semi metallic pads, and will make a squeal from time to time. There are NO wear tabs, but if you get down to the steel shoe you will know it. Mine squeals abit every morning on the first stop, and it goes away after that. If I push out of the shed it will squeal until I ride, and settle it in again. The other thing to look at would be the bearing inside the rear wheel. I have had several scoots that lost the rear bearing. You can test it on the center stand to se if there is ANY side to side play in the rear wheel. There should be 1mm or less for the entire assembly. Ideally there should be zero play.
Re: brakes
« Reply #3 on: May 07, 2010, 01:06:25 AM »
..mine were silent til i put those alien pads on....
