Author Topic: Rusten exhaust  (Read 1301 times)
scootergrisen
    • scootergrisen
Rusten exhaust
« on: May 07, 2010, 02:39:44 PM »
Do anyone have tips to make the exhaust not rust so easily ?
What tools and paint to use.
I live in a rainy country so other people living in dray places might not have this problem with rust at all.
I read sandblasting should be good... but who has a sandblaster. i dont.
Have a look here for exhausts that i have painted:
http://scootergrisen.dk/scooterhjemmeside/service_luftfilter.php
I tryed with black and transparent paint.
Also your suposed to heat the paint to 160 degre celsius for 30-60 minuts but who as a exhaust sized oven.
I have heated the paint by running the engine but maby the front section of the exhaust gets to hot and other parts not enough.
And tips ?
« Last Edit: November 01, 2013, 05:17:37 AM by scootergrisen »
olbull
Re: Rusten exhaust
« Reply #1 on: May 07, 2010, 03:04:14 PM »
Good  old fashioned  Stove  Black  paint..spray  or  brush on...
2007 P250
If  your  not the lead dog the  scenery never  changes
winginman
    • Accugen DNA Service
Re: Rusten exhaust
« Reply #2 on: May 07, 2010, 03:35:21 PM »
Man, you have done everything I can suggest...  I followed your process on the link you gave.  The black sure did look good after you finished and you used paint that should have easily withstood the hear.  650 C (1200 F) is really hot and is as good as any exhaust manifold paint I have seen.  Only thing I can suggest would be multiple coats of the black with the hardening process in between coats.  You look for something that bonds and give a porcelain finish, then again this usually has to be baked on at high temperatures.
Jim
09 Kymco 500Ri (His)
04 Aprilia S500 (Hers)
01 Honda GL1800 (Ours)
DNA Paternity Testing www.accugendna.com
Re: Rusten exhaust
« Reply #3 on: May 07, 2010, 04:53:40 PM »
...i never have let mine get in the condition that those pics show, but i sand off any rust, then prime with Rust-o-leum industrial spray primer, then just spray on a couple of coats of Rust-o-leum industrial semi-gloss black...
..that generally last for several months, then I do it all again...
scootergrisen
    • scootergrisen
Re: Rusten exhaust
« Reply #4 on: May 07, 2010, 10:09:31 PM »
winginman > Why do you think it would be better with multiple coats + heatings instead of just 1 coats and 1 time heating ?
I would think it would be better with just 1 time heating because i think if you do it more times the layers get hard and the new coats wont stick so good.... but im just guessing.
Also when i ride the exhaust hot, some dirt from the road got in the exhaust and and paint get "soft" when it gets heated so the dirt sticks to the hot paint i think so doing multiple layers my result in aslot of dirt inside the paint layers.
